Oil cap problem!
Posted 10 March 2007 - 02:23 AM
Posted 10 March 2007 - 08:30 AM
About once a week or so i take my oil cap off and there is a thick layer of, well gunge frankly! piled upinside the cap, if i've been out around in the day then it builds up a bit but not much, any ideas why? as far as i can figure is that i need a headgasket because its mixing oil and water but im not especially good with engines so im not sure! i can provide pictures if necessary
pics would help,what colour is "gunge"?
ROD:)
It *could* just be that you need a new rocker cap, as they are supposed to be vented, so if yours is blocked it may, at a guess, cause the same problem?!
Has the engine seemed down on power at all, or does it struggle under load?
Moved to Technical.
Posted 10 March 2007 - 09:48 AM
What do you use the car for ? Lots of short journeys, especially in winter, will also cause this problem and a good blast down the motorway to get everything upto temperature is required every so often.
As said above it could also be the head gasket.......do you need to keep topping up the water level?
Posted 10 March 2007 - 11:33 AM
Almost certainly 'mayonaise' or emulsion to give it it's technical term.
nope the water levels are fine! im leaking a bit of oil and some petrol from somewhere but thats about it! i have 2 pictures now, its not as such mayonaise, more brown/greenish! generally i use it for short journeys yeah, only a few miles a day (weekend about 50 miles or so?)
As for the cap, it does have a hole in the top but if i 'pump' the lid it sprays a bit of water and gunge out the top so there is still access i think! just builds up a bit and makes it worse im imagining!
Reckon its the headgasket then?
Posted 10 March 2007 - 11:47 AM
Posted 10 March 2007 - 11:48 AM
hello mate. As long as the oil isnt this colour on the dipstick. i use my car for short journies, and it does this. It never used to do it with the thin steel rocker cover, but its really bad with thick alloy one. I guess its because it doesnt get warm as quickly.
the dipstick is fine! all nice and oily
Posted 10 March 2007 - 12:12 PM
Posted 10 March 2007 - 12:26 PM
Posted 10 March 2007 - 01:53 PM
Posted 10 March 2007 - 04:33 PM
Posted 10 March 2007 - 04:47 PM
And every so often take the whole rocker cover off and clean the inside of this because that emulsion will probably be across the whole underside of it.
ok thanks! can't do it now but i'll give it a go tomorow!
Posted 11 March 2007 - 07:02 PM
But it seemed okay afterwards, even though that Mini generally only did short journeys.
