Can I hammerite....
9 replies to this topic
#1 karl & his cooper
karl & his cooper
  • 915 posts
Posted 11 March 2007 - 03:57 PM
Can I hammerite..the brake servoy bit?
engine block/cyclinder block where the sparks go in?
The brake calipers?
The shock/dampener under the front wings?
Also while im here...its been ages since my minis had a proper polish *bad owner :xxx:( * her paint is red, and obv has lost her shine and has something called gloom or bloom or something from the rain...in other words whiteish marks/spots
...how do i get my mini shining again? And what do I use?
#2 *DJH*
*DJH*
  • 4,972 posts
Posted 11 March 2007 - 04:04 PM
Hi, Please See Below.
Can I hammerite..
the brake servoy bit? Wouldn't Advise It Unless It Was Very Thin.
Engine block/cyclinder block where the sparks go in? Yes But Not The Threaded Holes.
The brake calipers? Yes But Obviously Not The Seals/Nipples/Hoses Or Pistons.
The shock/dampener under the front wings? If You Mean The Damper Unit Then NO. If You Mean The Mount Then Yes.
Edited by DJH MINI MOTORSPORT, 11 March 2007 - 04:05 PM.
#3 mkw
mkw
  • 1,003 posts
Posted 11 March 2007 - 05:55 PM
For the shine use meguiars quick clay and then a good polish, it will look like glass!!!
#4 smudger
smudger
  • 1,854 posts
  • Local Club: Lots
Posted 11 March 2007 - 06:00 PM
Get the Meguairs Quik Clay pack, wash car first (goto General Chat and see GB because thats perfect for it)
Spray the detailer on and use about 1/3 of the clay (need it nice and soft) then do small sections at a time, till whole car is glass smooth.
This will get rid of some small scratches and swirls as well.
Wash car (2 bucket shampoo)
Feeder wax followered by sealer.
Whilst not the very best way of waxing car this will be good for everyday use.
If paint is still "faded" then you really need to use a Paint Cleaner or similar (removes a layer of paint) and then the above.
Want more detailed about washing and waxing?
(just clayed the Mini roof and its FANTASTIC now)
#5 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 11 March 2007 - 06:02 PM
Can I hammerite..
the brake servoy bit? Wouldn't Advise It Unless It Was Very Thin. i got to say yes you can its a sealed unit with a union coming out of it so painting it wont effect the way it worksEngine block/cyclinder block where the sparks go in? Yes But Not The Threaded Holes.
The brake calipers? Yes But Obviously Not The Seals/Nipples/Hoses Or Pistons. you can acyually paint the nipples as long as you keep the ends clear, and painting the threads when there fitted and locked of wont affect anything either.The shock/dampener under the front wings? If You Mean The Damper Unit Then NO. If You Mean The Mount Then Yes. again i have to say yes you can, just dont paint the plunger but you can paint the lower case and the outer top cover.
Edited by cowboy, 11 March 2007 - 06:03 PM.
#6 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 11 March 2007 - 07:54 PM
Whats Meguiars Clay?
#7 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 11 March 2007 - 09:56 PM
google will have the answer surely mate!
It's a clay that you rub across paint... it picks up embedded dirt and grit, leaving you with a smooth 'paint only' surface to polish.
It's just means you're not trying to polish a turd.
#8 mkw
mkw
  • 1,003 posts
Posted 11 March 2007 - 10:43 PM
Its the best cleaning product ever!! Gets rid of everything, overspray, tar, salt etc
#9 Big_Adam
Big_Adam
  • 7,435 posts
Posted 12 March 2007 - 01:38 AM
I use Japlac on my cylinder head. Came out nice,
[attachment=28952:DSCN1508.JPG]
#10 Ell100
Ell100
  • 517 posts
Posted 12 March 2007 - 12:00 PM
i painted this using hammerite.... and a paintbrush :xxx:
