Stage 3 Tuning MPI @ MiniSport
Posted 12 March 2007 - 10:28 PM
Please reply and let me know how you rate the performance after the mod. Cheers guys!
Posted 13 March 2007 - 12:38 AM
reading this gave me an insite to the complications of injecting the a-series!
emeralds a-series injection project
Posted 13 March 2007 - 01:07 PM
yes it is worth doing, but i would consider changing the diff to a 3.44 as well.
Its not quite as fikus put it but not far off, the problem is the head and that all 5 ports suffer from charge robbing of some sort. the MPI more than others.
If you want to talk about it you can pm me and i'll let you know what to do.
Also remember that most mpi's only make 88 bhp with this conversion.
Dev
Posted 13 March 2007 - 07:57 PM
Posted 14 March 2007 - 12:15 PM
At least you bothered to put a constructive reply which is better than just "bin it and put a carb motor in"
Posted 14 March 2007 - 12:45 PM
Posted 14 March 2007 - 01:35 PM
all i will say is its expensive and i am struggling to build the required bits
Posted 14 March 2007 - 01:45 PM
just out of intrest are the bhp figures you said about at the flywheel?
Posted 14 March 2007 - 01:49 PM
Hi,
Yes the 90 bhp kits rarely make 90 bhp normally 88 at the fly.
Posted 14 March 2007 - 08:04 PM
is there anyway to stop the port robbing or is that impossible?
Yes
Use seven or eight ports
Posted 14 March 2007 - 08:55 PM
only other thing i saw, right about the time twin point came out, someone was using 4 injectors, 1 pointing at each port!! i dont know how succesfull this was!
Posted 14 March 2007 - 09:49 PM
Easiest fix is to run a wet manifold instead of port injection, that way the fuel/ air mix is all the same at the port and each cylinder draws in the same ratio mix.
Again there is a big myth that the MPi will give more power. It doesnt. What it does do is improve emissions.
Its the engine that produces power. The fueling, if inadequate is what restricts the engine producing power.
The MPi suffers on port injection because at higher RPM, there is such a tiny injection period, any 'powerfull' engine needs lots of fuel. Thats the difficult bit. Port robbing reduces the period to inject all the fuel for that cylinder cycle, even further. There just isnt an injector thats fast enough that can sqirt the right amount of fuel. The point of the injection is what is being looked at and to date, the MPi ECU is the only one that achieves it. Real pitty that its locked code.
As for the 7 port head, yes it does get rid of the port robbing but it is far from perfect. The shape of the inlet ports on the outer cylinders is pants. The 8 port is a better port design. There is no substitute for the real thing. However forgetting the inadequacies, the 7 port is deffo a 'budget' option. Stick a turbo on it and these inadequacies almost disapear.
