mine did this. it turns out the bit on the bottom of the carb had bent. so check your carb is in workin order.
Engine running problems!!!
GazPatrick
, Mar 16 2007 04:31 PM
18 replies to this topic
#16
Posted 17 March 2007 - 10:27 PM
#17
Posted 17 March 2007 - 10:33 PM
just to recap i can go out on a 5 mile jorney and it will be fine, and another day i will do the same and it will start to judder and jolt.
I can't see how a carb/fuelling problem could be causing it to be honest
#18
Posted 17 March 2007 - 10:40 PM
well if you've definatly tested everything else that's all that's left....
#19
Posted 18 March 2007 - 03:25 PM
I've not tested everything yet and was just asking what else i could check...
I changed the dizzy cap and rotor arm this morning and i'll see how that goes but if not i'm going to have to go and get a new condenser and points, which halfords say they don't have on the shelf anymore so its going to have to be ordered!
