t2 turbo
3 replies to this topic
#1 MINIMON
MINIMON
  • 454 posts
Posted 17 March 2007 - 07:47 PM
hi what cars have t2 that can donate me my turbo and whats the best setup for this turbo (head,pistons is it the same as the t3 ? plus ive got a 1300 engine but im not sure what type (metro turbo,metro, mini)? any ideas as to how to find out.
Also has anyone done a complete guide on how to fit megajolt/megasquirt?
#2 blacktulip
blacktulip
  • 6,224 posts
Posted 17 March 2007 - 09:37 PM
the turbo your after is any of the T2 range, be it a T25 or just the standard R5 gt turbo one is the most common of the T2's. have a search through the section for all your needs. also check out www.turbominis.co.uk. this will answer most questions.
#3 josh_tacon
josh_tacon
  • 123 posts
Posted 23 March 2007 - 03:47 PM
you would want a t2 with a 4 studed flange as theres a few (fiesta i think is one) that is 3 studs.
you could either use the mirage kit which is £300 or you could make up or buy a bracket which allows you to use the standerd metty turbo manifold.
iv heard that the mirage manifold is restrictive compared to the mettey manifold as its designed to fit without any bulkhead mods, which means it has tight bends, which is not good for optimum flow.
hope that helps.
cheers
josh
#4 MINIMON
MINIMON
  • 454 posts
Posted 23 March 2007 - 07:03 PM
Thanks I will have to custom make the manifold as the turbo is being siode mounted thanks for the turbo info though
