Suspension Questions
Posted 19 March 2007 - 06:59 AM
I have done a search but cannot find the answer i want. I am going to lower my mini and want it fairly low. How much can it be lowered by?. Where do you take the measurement on a mini for castor?.
Are the camber, castor & toe in/out different for 10" to 13" wheels??
Paul
Posted 19 March 2007 - 11:55 AM
You can usually lower a mini as much as you want to...
Front wheels...you can get camber/castor gauges.
Optimum settings vary depending on wheel size, yes. For example less negative camber is recommended on a 13" wheel mini to that of a 10" mini. From memory, the Mini Spares website has some good articles on all of this stuff; ride height, geometry etc.
Posted 19 March 2007 - 12:06 PM
....I think.
Posted 19 March 2007 - 08:26 PM
well there is a limit - you really need some clearance between the front bump stops and the top arms.
some remove bump stops, bad practice that results in ball joints breaking.
at the back - things easier, but you need to watch the brake pipe...
castor is at the front - basically its the camber change between 20 degs turned in, and 20 degs turned outWhere do you take the measurement on a mini for castor
yes - each wheel size has a different setting, the setting i use when setting up 10" are different than when i setup 13". not wildly different, but, for example, where a 10" car can have lots of camber (lots = max 1.5deg- on a roadie), a 13" car i would run at the very most 0.5 degs neg..Are the camber, castor & toe in/out different for 10" to 13" wheels??
Posted 19 March 2007 - 11:07 PM
Any cheat ways of setting this up without all the measuring tools a garage gas?
samwell
Posted 24 March 2007 - 01:11 PM
But you can lower it as much as you want...just depends if you want to do things like cut bumpstops down/remove bumpstops
I had my previous mini very low...and yes it did knock out balljoints every 6 months or so, and exhaust front link pipe just about as often where it hit the road
Posted 24 March 2007 - 03:33 PM
Posted 29 March 2007 - 02:56 PM
Could remove bump stops and put coilovers with a built in bump on the damper then you will have to cut out inner arches and outer arches, you'll get a lot of oversteer when you have the grip but a soon as one wheel reaches it maximum movement in the motion of suspension you'll get understeer and that will make it handle like a pig.
Mine didn't have a lot of shock travel and suffered with understeer badly when really chucking it in...like doing a u-turn on a mini roundabout. Apart from that it was pretty good, considering it only had about 1cm travel at the front...
