Minis pulling to the Right
Posted 21 March 2007 - 08:07 PM
Posted 21 March 2007 - 08:09 PM
Posted 21 March 2007 - 08:13 PM
Posted 21 March 2007 - 08:40 PM
i also forgot to mention it only does this when i apply the brakes. she drives great down the road.
Posted 21 March 2007 - 08:44 PM
Posted 22 March 2007 - 01:06 AM
an even easier way would be to just get someone to sit in the car with it on axle stands, put on the brakes and then try to spin each wheel to see if the left one still moves.
Posted 22 March 2007 - 02:29 AM
Have you bled the brakes fully / lately? Could be an air lock.
Had something similar on my car before it was rebuilt, only the front left barake was the ONLY one working correctly (that was a fun trip to the garage, ALL down hill for nearly 2 miles!! )
SS
Posted 22 March 2007 - 09:48 AM
thanks for the help
Posted 22 March 2007 - 10:13 AM
After that, the drums had a good surface and were totally true. The car handled perfectly after that and braked much better.
yeah, i have drums
i am going to install new calipers on the left side this weekend and see if that helps.
Have you got drums or Discs!?
Edited by Retro_10s, 22 March 2007 - 10:14 AM.
Posted 22 March 2007 - 12:07 PM
Posted 22 March 2007 - 03:43 PM
Posted 22 March 2007 - 06:06 PM
I'm pretty sure you will find a seized or leaking wheel cylinder in there somewhere, more likely at the front on the side opposite to the way it pulls.What kind of brake bias would there be on this type of Mini? Maybe there's a problem with that perhaps?
Remove the wheels and drums, and peel back the rubber dust covers to check for leaks. If there is no evidence, remove the shoes, and use a large screw driver in the slot of the piston to see if to see if it turns in the cylinder.
Other possibilities can be poor adjustment, because on most tls mini drum brakes the previous owners have usually rounded at least one if not both of the adjusters off. Oh, and always adjust in the direction of rotation of the wheel.
Posted 28 March 2007 - 08:20 AM
