what ancilleries to put on engine before it goes in car?
jefinabox
, Mar 24 2007 02:09 PM
9 replies to this topic
Posted 24 March 2007 - 02:09 PM
Howdy, just about got the metro engine ready to go in the mini, but I'm not sure which ancilleries to fit before i shove it in and if anyone has any general tips, any help would be appreciated, mucho thanko,
jef
jef
Posted 24 March 2007 - 02:34 PM
upgrade subframe mounts to solid ones?
(i would anyways)
(i would anyways)
Posted 24 March 2007 - 03:25 PM
Just fit the two manifold and the radiator and brakets leave rest off personally.
I think he means what to put "on the engine" before he puts the engine in the car.
My advice would be to put very little on the engine, especially not those things that can easily be reached from above or the front. I have a remote shift gearbox. On cars with that transmission you have to tilt the engine at just the right angle to get it in the car. As such, I take off (leave off) the intake manifold and carbs, the dizzy, and the starter. Not only is it lighter this way, it's also got fewer things sticking out in the way... or sticking out to potentially get damaged. I tie the exhaust to the firewall tucked back as much out of the way as possible.
Posted 24 March 2007 - 05:37 PM
Check your speedo cable fits, as the Metro ones are often a different size... Its easier to connect this whilst the engine is up in the air, but check that the cable fits first...
Everything else can be done once the engine is in.
Posted 25 March 2007 - 01:37 AM
There is an additional point about the speedometer cable that I'd forgotten about. The Haynes manuals will tell you to partially install the engine and THEN attach the speedo cable to the gearbox. While there may be Minis where this makes sense... it certainly doesn't apply if your car has the center binnacle of the early cars. It's MUCH easier to attach the cable to the gearbox and tape it up/over the engine prior to installing the engine. After the engine is in place on its mounts, route the free end of the cable to the speedo and re-attach it.
Syholl, what is the Mustang in your avatar doing over there? That car looks great but it also looks terribly out of place in Europe.
Posted 25 March 2007 - 07:47 AM
Thanks for your advice, really appreciate it. LOVE the mustang, and the colour. my dream car is a 69' mach1... she will be mine... oh yes she will be mine....
Posted 25 March 2007 - 08:25 AM
might be an idea to fit the fuel pump first, unless you using an electric one
Posted 25 March 2007 - 08:37 AM
I have always loved the American muscle cars, and the Ford Mustang in particular, so when i saw that 1970 Mustang fastback for sale i just had to have it. There is nothing else that sounds like a big block 7.5 litre V8...
Posted 25 March 2007 - 08:40 AM
O/T but sy that car looks
gorgeous mate, please tell me it's gonna put in an appearence at a show this year?
