electrical problem
5 replies to this topic
#1 yverthongen
yverthongen
    Just On Tickover
  • 9 posts
Posted 25 March 2007 - 02:58 PM
hey,
I had a cd-player installed yesterday afternoon. It worked for the ride home but when I wanted to leave at night, my horn, flash beam and radio didn't work any more. I have a '93 British Open with a carburator engine. Does anyone have any ideas how i might be able to fix this?
Thanx,
yverthongen
#2 rozzer!
rozzer!
  • 2,367 posts
Posted 25 March 2007 - 03:45 PM
hey,
Thanx,
yverthongen
check the fuse and if its blown, replace. if it blows again get a slightly higher amp one to compensate!
#3 yverthongen
yverthongen
    Just On Tickover
  • 9 posts
Posted 25 March 2007 - 03:54 PM
where can i find the fuse? I'm sorry, but i'm really novice and i've only had this car for two weeks (it's my first car)
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 25 March 2007 - 06:20 PM
ARRRGGH. NO NO NO NO NO.
Will people please stop giving this dangerous and potentially life threatening advice. The fuse protects the car from fires, don't change the rating.
Did it all fail at once? Were you flashing the lights with the radio on when it failed? If so it sounds like your stereo has been wired into the headlamp flasher / horn fuse and overloaded it which is dodgy and shouldn't be done. There is a specific radio circuit on this Mini. If this was done professionally I would take it back. In your fuse block which is under the bonnet there are 4 fuses. The second one down is the one to check. Replace it with one of the same rating and see if it blows again. If it does there is a fault.
#5 yverthongen
yverthongen
    Just On Tickover
  • 9 posts
Posted 26 March 2007 - 08:30 AM
It did indeed fail all at once, but not by doing anything like flashing my lamps of whatever. I started my car and wanted to listen to the radio when i noticed that it didn't work. when i wanted to flash my lights further down the street i noticed that this didn't work too. I'll try to locate the fuse and replace it next weekend, 'cause i'm not home the following days. Thanks for your advice Dan.
Yannick
#6 yverthongen
yverthongen
    Just On Tickover
  • 9 posts
Posted 31 March 2007 - 08:19 PM
i had it fixed now by the garage that fitted the radio. it works well now... thanx a lot for your help with my first little mini problem
yannick
