so whats so good about em?
vented discs
mic
, Mar 25 2007 07:00 PM
8 replies to this topic
Posted 25 March 2007 - 07:00 PM
Posted 25 March 2007 - 07:10 PM
Because they can lose heat better which is one of the keys to good braking performance.
Posted 25 March 2007 - 07:13 PM
yea but so do drilled?
Posted 25 March 2007 - 07:43 PM
Nothing really good about them.
They add weight to the unsprung mass
They make the wheels stick out further
Are over the top ( standard solid discs are adequate)
Posted 25 March 2007 - 08:10 PM
No they do not. Common mistake. Drilled holes in discs are there only to allow the build up of gas that can form under the pad during heavy braking to escape because otherwise the pad floats on the gas like a hovercraft and you loose braking efficiency. This is essentially the real cause of brake fade. Grooves on discs are there only to clean crud off the face of the pad. Neither of these add any serious cooling capacity to the disc. Vented discs have a large air space inside them and a from of turbine designed to draw air into the space and force it to flow through the disc while it is turning, actively cooling it.
Posted 25 March 2007 - 08:39 PM
Am i right in saying Dan that you can buy 'vented, cross drilled and grooved' disks, i'm pretty sure i've seen this on an ex-sierra cosworth touring car.yea but so do drilled?
Posted 25 March 2007 - 08:50 PM
You can but you must remember the hole goes into the vents thus allowing the pressure to diapate
Posted 25 March 2007 - 08:52 PM
That's what i thought.
Posted 26 March 2007 - 04:52 PM
Standard discs are fine for road going Minis, but I've found EBC Greenstuff has helped prevent brake fade and I get less brake dust on my alloys too.
