Indcaters not working properly?
15 replies to this topic
#1 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 26 March 2007 - 07:08 PM
Hey all...
Was out in the Van, and then the indecaters had stopped blinking... they come on, but stay static, what could be the problem with the flashy part?
I did was the Van earlier today... could water of got into somewhere?
Cheers :thumbsup:
#2 Globule
Globule
  • 1,134 posts
Posted 26 March 2007 - 07:10 PM
Hey all...
Cheers :thumbsup:
I had this in mine, was when i was indicating right, the front one had a dodgy connector and was a bit rusty so i cleaned it up and it works fine! maybe check there?
Does it happen when you indicate left and right? also do your hazard lights work?
#3 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 26 March 2007 - 07:13 PM
This happened to my old mini befor and i found out that the connectors on the incicator unit were dirty so i cleaned them and it works now. It also happened when the buld was broken.
#4 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 26 March 2007 - 07:28 PM
Well the hazards work perfectlly... the lights are nice and bright, none blown...
#5 vasi
vasi
  • 897 posts
  • Local Club: Minis 'n' Oatcakes
Posted 26 March 2007 - 08:20 PM
Hazard flasher is an independant circuit and live feed. The bimetal strip in the indicator flasher unit manifests fault in two different ways. Not coming on at all, or staying on permanently. I would suggest replacing that first, Halfords sell them, 22wx4 square or round type - doesn't matter which. Only a few pounds.
#6 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 26 March 2007 - 08:29 PM
So replace the Flasher Relay? and work out from there...
#7 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 27 March 2007 - 03:46 PM
Yes! :D
#8 rozzer!
rozzer!
  • 2,367 posts
Posted 27 March 2007 - 04:15 PM
best getting it from minispares, then you have a guarantee that its compatible. i got 1 rom halfords 3 months ago. and guess what! its already broken!
#9 vasi
vasi
  • 897 posts
Posted 27 March 2007 - 11:40 PM
Well guess what fifi. Take it back to be replaced. A part is a part is a part, who do you think makes these things? Might it be the same company?
#10 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 28 March 2007 - 06:33 AM
Surpised it even has hazards? What age is it??
#11 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 28 March 2007 - 08:38 AM
Dont buy flasher units from halfrauds, they are cheap nasty and dont last 5 minutes. You will get fed up with taking them back !
'Upgrade' it to a newer electrical unit, there is a post on here somewhere about it. Think Guessworks has done it to his, you just have to 'add' an earth wire.
#12 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 28 March 2007 - 07:31 PM
Well replaced the relay with the one off the White Mini - which was working... but they still stay static...
What can it be... grr
#13 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 28 March 2007 - 07:45 PM
A knackered old Van :D only joking mate.
Hmmmm can only suggest the usual demons such as bad earths, dirty connections and flasher.
#14 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 28 March 2007 - 07:49 PM
Yeh, going to try the earths the weekend... it worked Monday morning - after I washed it, it didn't :D
#15 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 March 2007 - 07:51 PM
Hazard switch, assuming it has the hazard switch I am thinking of. Hazards wouldn't be standard on a '68 van, where are they from?
