Posted 27 March 2007 - 04:53 PM
Rods...
there are 5 types of 1275 (big bore) rod,
Pre A+
A+
Innocenti
Cooper S
Midget (1275 not the 1500 thats a totsaly different engine)
The pre A+ and the innocenti are physicaly similar ( they have the big square bigend cap but the inno one is smaller) and weigh roughly the same ( the inno rod is a bit lighter) but the Innocenti rod is a higher spec steel i belive its EN19 rather than the EN16 of the Pre A+ rod
the A+ is lighter than all the other rods and made from EN15 and has rounded caps
the cooper S and midget rods are esentially the same except for the material, the miget rod is EN21 the S rod is En24, both have a 1.625" big end rather than the 1.75" of all the others.
The reason the S rod is smaller is all mini ends (850, 998, 997,1098 and S's) were 1.625 up untill the Material specs were downgraded in the 1275 engines, at Which point the 1.75" ends were introduced on the 1275's.
tomm
the 1275 1.75" rods are all interchangable, so thats a yes for A and A+
if you get S rods the crank needs to be reground/changed, also there is two lengths of S rod.
also depends what you mean by en16 crank? the small bore cranks were EN16...
all the 1275 engines (Including the S) are 81.33mm stroke
I'm not to up on the small bore engines so can't advise.
