Carbon fiber Roof skin
Posted 27 March 2007 - 07:45 PM
Now ive always been fond of the Carbon roof skins with the exposed weave.
When I buy the skin, Is it just a case of cutting out the old skin leaving an inch or so of "Lip" to bond the new Carbon fiber roof skin to?
Can I Rivet it on? Providing I put a sealing agent between the skin and the Lip?
Will I need to do any cutting/filing to get the new Skin to sit neatly in the Roof Gutter?
And finally, How much would a CF Roof skin set me back?
<|ben|>
Posted 27 March 2007 - 08:07 PM
Posted 27 March 2007 - 09:31 PM
<|ben|>
Posted 27 March 2007 - 09:58 PM
Posted 27 March 2007 - 10:09 PM
from a layman's point of view surely its going to sacrifice the strength of the shell in a major way, after all it is a monoque structure, even if you do have a cage in there too. i use f/g doors and i intend to put metal ones back on as i fear for my safety, even with a safety devices 6pt cage..
i worry about you guys when i think we take lightening too far, and in an accident.. well its scary. please tell me otherwise.
by the way thats a kick ass clubby, would you mind pm'ing some photos of your wheels/ arches/ body? i want to get rid of 13X7 minilights for some revos, but dont know on what size!!
Posted 28 March 2007 - 09:17 AM
However I advise in the STRONGEST WAY POSSIBLE, fit a Multi Weld Cage.
DONT buy a roof skin off ANYONE unless they advise that.
I would go for a CF weave layer with kevlar underneath. Little bit more weight, loads more strength.
The next problem your going to have is getting the roof done in one piece. I know Curley use's 3 to 4 different pieces of cloth to cover the roof.
What is it you want out of it? Looks or weight?
Posted 28 March 2007 - 10:19 AM
Lots of money to spend when that money can get you more weight saved in better areas.
Posted 28 March 2007 - 12:08 PM
Posted 28 March 2007 - 02:31 PM
so whats the difference in strength between fitting a carbon roof skin and fitting a full length sunroof ?
That's a damn good point Bungle! Though I assume there is some sort of frame bolted in there, you are cutting a similar amount of material away.
Posted 28 March 2007 - 03:08 PM
minimission, i will send u some pics later on, at work at the mo and ill get slapped if i get caught on here!
Posted 28 March 2007 - 05:54 PM
Posted 29 March 2007 - 01:06 AM
CF arches too.
<|ben|>
Posted 29 March 2007 - 10:46 AM
Posted 29 March 2007 - 01:13 PM
Posted 29 March 2007 - 01:33 PM
as far as i`m aware, The roof has a fair few dints in it.
So i guess a CF roof isnt needed but the roof would still need to be sorted out and if your sorting out the roof and you want the CF effect then i this is the perfect time to do it really...
