mini bangs in gear
Posted 27 March 2007 - 09:41 PM
Be grateful for any advice
Posted 28 March 2007 - 06:37 AM
Posted 28 March 2007 - 07:00 AM
Posted 28 March 2007 - 09:13 AM
Will check that later.
Clutch pedal is on floor to change. Will bleed clutch in case it has air in it and check how far out the clutch arm is too.
Will re-check the engine steady. Am sure the engine mounts are knackered too.
I am (fingers crossed) fitting a stage 1 over weekend, will fit Ulitmate Engine Steady at same time.
Now, what it it isnt the Engine Steady, will that narrow it down to the clutch?
Posted 28 March 2007 - 09:22 AM
Is it when you push it into gear? Is it when you put your foot back on the throttle? Is it when you push the clutch pedal down?
Posted 28 March 2007 - 09:25 AM
Posted 28 March 2007 - 01:16 PM
Posted 28 March 2007 - 02:02 PM
Engine steady bolt has sheared in block. 2nd bolt in if facing engine
Ooopsies!
I have never fitted one, but I believe that you can get repair kits for when this happens, so that the steady is bolted into a different position. It's either that or you'll have to get the bolt removed (drill down centre and use an easi-out).
Posted 28 March 2007 - 05:39 PM
Will find repir kit thanks
Posted 28 March 2007 - 08:13 PM
Posted 28 March 2007 - 09:03 PM
Posted 28 March 2007 - 11:02 PM
And looking at the Engine Mounts (bound to be broken if the engine steady hasnt been working for a while) together with the Engine Steadys from gearbox to subframe.
Posted 29 March 2007 - 06:49 AM
Posted 29 March 2007 - 07:24 AM
Posted 29 March 2007 - 08:56 PM
Whats the best way to fit the engine mounts?
