Box section tubing - For making a subframe
Posted 30 March 2007 - 08:36 PM
Right well erm lastnight i found a thread on 16VMC of a lad who had modified a standard mini subframe to suit a C20XE engine, I was looking at the Box section tubing and it seemed to be 30mm x 30mm but i wanted to know what a suitable thickness of the metal will be. i have been having a look around and the most common seems to be 2mm which is way to thin i would have thought so if you have modified your subframe for a conversion what messurements did you use? have you had any trouble with it?
I didi have a look through loads of threads on 16VMC and i thought Matt might have advertised it on one of his adverts for one of his subframes but i couldnt find it anywhere So any help would be great!
Also where would i be able to get it from? I would need a fair old bit of it as i am more than likely to screw up some where down the line!
thanks, Tomm
Posted 30 March 2007 - 08:43 PM
Posted 30 March 2007 - 09:11 PM
Posted 30 March 2007 - 09:43 PM
Posted 30 March 2007 - 09:58 PM
Thanks guys, i will have to have a look through the local directory and find some where local.
Posted 30 March 2007 - 10:00 PM
Posted 30 March 2007 - 10:08 PM
Posted 30 March 2007 - 10:22 PM
Posted 31 March 2007 - 06:37 AM
Yea, go 3mm to be on the safe side, but you'd be surprised at what a well designed subframe can take!............
to be honest I think that's the problem with home made subframes, they are not all designed and tested, they are made to fit an engine that wasn't originally meant to be in there. I would always tend to be overcautious with something like this and go for as thick walled material as is practical (without being stupidly heavy, or un-weldable). I mean, it not like you're going to be working out the second moment of area on the RHS and calculating any bending moments.
What part of the subframe will this be used to modify? I mean if it is just to make up engine mounts, then all you're doing is supporting the engine and stopping it from twisting itself out of the frame, but if you are chopping the front of the existing frame off then I'd be paying a lot more attention to detail, especially if you are using a flip front jobby! Tis harder to shape joints, but I'd rather see home made frames made from round tube rather than RHS!
As for 2mm seeming to thin, well, it's impossible to know without knowing what it is going to be used for and what loads it will be under, but you'd be surprised at how strong 2mm RHS can be
EDIT: RHS is Rectangular Hollow Section by the way!
by the way is By The Way (by the way)
Edited by mini mad me, 31 March 2007 - 06:39 AM.
Posted 31 March 2007 - 08:52 PM
Posted 02 April 2007 - 11:37 AM
Thanks though, i think i will go for some thing between 2.0- 3.5mil
