cleaning your block
4 replies to this topic
#1 russellbarrett
russellbarrett
  • 53 posts
Posted 30 March 2007 - 09:52 PM
i have a block which needs a bit of work on it and was wandering about getting it dipped, is dipping just for getting the scabby paint and C**p off the block or does it clean out all the oilways as well, if so, are there any alternatives for cleaning out the oilways or is it just a case of paying to have it done? just looking at ways of keeping costs down.
russ
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 30 March 2007 - 10:15 PM
Clean the oil ways the way your suppost to.
Drill out the brass plags, tap the hole and scrub the oil ways out with a long rifle brush.
#3 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 30 March 2007 - 10:20 PM
Don't know if this is any help but look at this website 8 paragraph down. Will get rid of the rust in the block but won't clean out the oil ways.
Now, there is a cost-effective way to get rid of all the rust out of the block (and the cylinder head too) without any special high-tech tools. Simply mix up a solution of molasses and water (one part molasses to three parts water) in a plastic tub. If the mix is too thick to get into the water ways easily, you may need to thin it out a little with more water.
#4 aussie
aussie
  • 267 posts
Posted 31 March 2007 - 11:23 AM
if you want cheap dipping check out the for sale a guy has a tank and is doing it well cheap!
#5 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 31 March 2007 - 08:31 PM
PM Guessworks.
