squeaky suspension
8 replies to this topic
#1 miniallsort
miniallsort
  • 4,723 posts
Posted 01 April 2007 - 07:17 PM
when ever i go over bumps in the mini there is always a funny squeaky noise comming from the suspension what can i do to get rid of the squeak???????
cheers miniallsort :xxx:
Edited by miniallsort, 01 April 2007 - 07:19 PM.
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 01 April 2007 - 07:24 PM
When was the last time you greased all the points on your mini?
#3 steveobennet
steveobennet
  • 944 posts
  • Local Club: stu's turbo club
Posted 01 April 2007 - 07:25 PM
if you do grease you mini regularly, then if possible raise it off the ground and look for anywhere you think it might rub
#4 *DJH*
*DJH*
  • 4,972 posts
Posted 01 April 2007 - 07:30 PM
Also check the exhaust rubbers as they do squeak from time to time.
#5 miniallsort
miniallsort
  • 4,723 posts
Posted 01 April 2007 - 07:35 PM
i have greased the nipples is there any where else that needs greaseing??
#6 baker_boy
baker_boy
  • 971 posts
  • Local Club: "wot no brakes"
Posted 02 April 2007 - 12:49 PM
it could just be the damper squeaking, as one of mine has startd to squeak, and i had a look at it and it seems to have leaked oil so it needs replacing, you running standard dampers? try pushing the car down a few times on each corner to see which one squeaks.
Edited by baker_boy, 02 April 2007 - 12:51 PM.
#7 miniallsort
miniallsort
  • 4,723 posts
Posted 09 April 2007 - 05:31 PM
wd40 did the ttrick i think we will have to see
#8 Minwah
Minwah
  • 237 posts
Posted 11 April 2007 - 02:37 PM
Worn knuckle joints always cause a squeak...high pitched and very annoying. Check to see if the rubber gators have come away...the rear is especially prone to this and it is not easy to see, or sort out if the gator has popped off! If the gator has been off for any period of time then the knuckle joint will want replacing really, as it will be full of grit and will be worn.
My tip is if you replace the knuckle joints, use a bit of lockwire around the gator to prevent it easily coming off in future!
#9 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 11 April 2007 - 02:56 PM
Don't use WD40 as a solution! Depending on where the squeak was the Dub Dee will wash out the lubricant that was already there. Where did the WD40 get sprayed when it did the trick?
