how do i remove the oil pressure relief valve? (standard bullet type not ball bearing)
i have removed the nut and spring but dont see how to get the plunger out! its a bare block so ive turned it over and tryed knocking/taping it and using a long magnet but still cant get it out! am i missing something obvious?! lol!
many thanks for any help
tom
removing oil pressure relief valve?
Russell
, Apr 02 2007 10:07 PM
2 replies to this topic
Posted 02 April 2007 - 10:07 PM
Posted 02 April 2007 - 10:15 PM
i normally just stick little finger in there or if you have a wooden valve lapping tool pull of the rubber and is the right dia to push in and should pull out the plunger
should not be stuck
should not be stuck
Posted 02 April 2007 - 11:17 PM
I used a wooden dowel rod... smaller than the diameter of the valve. Then use masking tape to wrap around the end, making it fatter and thicker. Tap it in slowly so that the masking tape should get wedged into the plunger then pull it out!
