Which cylinder head for a 998 A+
Posted 03 April 2007 - 10:02 PM
I currently have a 998cc A plus engine with a stage one kit and a high lift cam. I am considering getting a different cylider head but not sure which would give me the best performance. Would a 12g295 head be best?
What work would i need to do to fit this head? Would it be worth it? I dont want to go for a 1275 as insurance costs are an issue so i was thinking of just modifying my current 998. I know i would need to declare all modifications to the insurance company.
Thanks for all help!
P.s. I have spent the past hour searching before posting this topic
Posted 03 April 2007 - 10:24 PM
either that or buy a stage 3 from morspeed or the likes
and yes. to get the best out of your cam you need a modded head
Edited by stef, 03 April 2007 - 10:24 PM.
Posted 03 April 2007 - 10:38 PM
Posted 04 April 2007 - 08:07 AM
You say to get the best out of my cam i will need a modded head but what modifications would i need to do to get the best performance? I dont want to buy a morspeed stage 3 as they cost around 800 if i am correct. If i get a 12g295 head what could i do to it to improve my overall performance?
Dan
Posted 04 April 2007 - 12:40 PM
Posted 04 April 2007 - 01:01 PM
Whichever head you choose, consider doing a cam change at the same time to maximise the benefit of both mods.
i can whip it off for u if u want it, postage would be high as its heavy but i live in brum if its any good to u
if u do a search on the topic "found a head" or something like that u will see pictures, its got double valve springs and cast rocker gear on IIRC
Posted 04 April 2007 - 05:47 PM
How much would i have to have skimmed off tog et the best compression or does it vary from engine to engine? I have heard a lot of people talk about getting an engine pocketed but what does this actually mean/involve?
Jimmyarm i have already got a different cam. just spoken to my dad and he think he bought a fast road cam from mini sport
Dan
Posted 04 April 2007 - 05:51 PM
Posted 04 April 2007 - 06:13 PM
What modifications can i do to my current head to improve it and how good would this be compared to a 12g295 head?
Dan
Posted 04 April 2007 - 07:49 PM
you can get your head ported, flowed and polished, double valve springs etc.
if you look in the faq section, im sure there is a post where it shows you what heads have what size inlet and exhaust valves.
at the end of the day its a 998, around stage 3 spec would be fine for you really. and i would advise a kent cam or an sw5. the one you have probably isnt gonna get thes best out of your engine. depends what you want. you can go for a mental cam but it'll do your head in round town.
Posted 04 April 2007 - 09:15 PM
As for improvements you can do to your current head,
David Vizard: Tuning The A-Series Engine
Just buy it and read it. It will tell you (almost) EVERYTHING about making your engine work harder and go faster.
And seeming as I'm hear, pocketing the block is were a cut out in the block is made to stop the valves in the head smashing into the block at high speed. The cut out allows for valves to get to full hight without smashing into the block and buggering the engine in a massive and expensive way.
Posted 04 April 2007 - 10:33 PM
http://www.theminifo...showtopic=45065
