Mini Wheels on a Metro
11 replies to this topic
#1 minidude03
minidude03
  • 462 posts
  • Local Club: Mini Club Jersey
Posted 04 April 2007 - 12:31 AM
what modifications will i need to make to get mini wheels on an austin metro
#2 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 04 April 2007 - 12:40 AM
the offset is wrong meaning they will stick out to far
but other that should go straight on as long as A series engined metro
if it is a later metro stud pattern is differant
#3 minidude03
minidude03
  • 462 posts
Posted 04 April 2007 - 05:08 PM
does anyone know how much they would stick out
and would this mean the wheel bearings would wear out really quickly
wats the difference in offset between metro and mini wheels
Edited by minidude03, 04 April 2007 - 05:11 PM.
#4 minidude03
minidude03
  • 462 posts
Posted 06 April 2007 - 11:48 PM
anyone???
#5 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 07 April 2007 - 11:47 AM
the metro and the mini PCD is different, the mini has a PCD of 4 inchs and i think metro has....3.75 inch PCD?? but not sure if thats all of them etc
as for the offset from the arches? that would depend where the wheel centre is in the wheel, depending which wheels
#6 WEBER45
WEBER45
  • 108 posts
  • Local Club: BUMPSTART MINI CLUB
Posted 07 April 2007 - 03:02 PM
anyone???
Mini wheels look smart on a metro but it depends on the width, size and offset of the rim as to what mods are needed.
Edited by WEBER45, 07 April 2007 - 03:05 PM.
#7 Jammy
Jammy
  • 25,397 posts
Posted 07 April 2007 - 05:57 PM
As the Stig says, certain Metros use the same hubs as Minis, those Metros with an A series engine, so the 1 litres and 1.3s.
Moved to Technical, should get more of a response in there.
#8 minidude03
minidude03
  • 462 posts
Posted 08 April 2007 - 12:42 PM
basically i want to put 7x13 starmags or alleycats on an austin metro knightsbridge 1275 a series engined
#9 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 08 April 2007 - 12:54 PM
The only problem you may come across is that the larger, wider wheels may scrub the arches. And cutting metro arches pleasingly is not as easy as on minis.
#10 minivanman
minivanman
  • 3,454 posts
Posted 08 April 2007 - 03:01 PM
It would be more pleasing to cut the metro up entirely and just save the engine :(
Edited by minivanman, 08 April 2007 - 03:01 PM.
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 08 April 2007 - 03:25 PM
Are we all forgetting about the alignment lugs on the Metro driving flange? Or are they only on MG Metro flanges?
:(:lol:
Edited by Dan, 08 April 2007 - 03:27 PM.
#12 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 08 April 2007 - 06:23 PM
Interesting point dan, I've only heard People mention the lugs on the MG flange, but i'm not sure whether or not that means they're not on the std 'tro flange or not. Easy enough to grind them off though if they are present. :(
Edited by Retro_10s, 08 April 2007 - 06:25 PM.
