Boring??
Posted 27 October 2004 - 10:32 PM
Posted 27 October 2004 - 11:28 PM
I've heard that 1380 (73.5mm) turbo's go well, but you have to remember to keep the compression ratio down ( increasing the bore also increases the compression ) and turbo's need lower CR's..
Re carbs, why use anything other than what the turbo was designed to use ?
Posted 28 October 2004 - 09:10 AM
I know there's a bloke on turbomini's with a 1380 turbo, i think he runs about 15psi and it goes pretty well apparently.
Just stick with the standard turbo carb, there's no way you could put twins on without fabricating your own inlet manifold then you'd also need to make a plenum chamber aswell. plus there probably wouldn't be enough room in the engine bay without even more bulkhead mods, and access to the turbo and the downpipe clamp would be impossible.
basically forget most things about tuning an N/A engine when it comes to a turbo, they're completely different!
Posted 28 October 2004 - 01:19 PM
It has five different modes he can switch between, each mode altering the boost and ignition/mixture settings.
He can put it on the tamest setting and use it for pottering the shops with no prblems and even returns reasonable mpg! But flick a switch and it turns into a 7mpg guzzler.
last time i seen him it was running about 147bhp at the wheels and apparently he's done a lot more on it since.
Posted 28 October 2004 - 06:07 PM
Posted 28 October 2004 - 06:10 PM
Posted 28 October 2004 - 07:52 PM
getting to the point, don't bother injecting just spend the money you save on making the engine strong.
DAN
Posted 28 October 2004 - 08:28 PM
Posted 28 October 2004 - 08:45 PM
as for the rebore swiftune are charging £70 for a +.20 rebore and £35 for a centre main strap to be fitted, this sort of price is probably about the going rate at most places i would imagine, make sure you budget for a rebuilt gearbox, and probably straight cut drops, turbo phil will probably know more about that sort of thing.
HTH
DAN
Posted 28 October 2004 - 08:52 PM
£150 on turbos 2nd hand
£70 on rebore
£35 for centre main strap (whatever that is?)
Also I will need?? bigger pistons and rings. What else wil need uprating?? I also assume the gearbox will be bloody expensive.
Posted 28 October 2004 - 09:04 PM
a centre main strap keeps the centre bearing for the crank shaft nice and tightly secured, it is pretty much an essential on any reasonably tuned mini engine, the prices for turbos is just a guide, don't follow it religiously, do some research and make sure you take the time to find a good one, there's plenty out there, the gearbox would cost about £350 for a fully rebuilt standard box fomr most mini suppliers, aim for some special "turbo" pistons, they have a larger dish to drop the compression ratio, (this is important on a turbo motor, especially if you want to run high boost) i think mini spares do some good ones, they come with rings too i believe, its probably worth gettig the crankshaft tougened, but i'm not sure sure how much it costs,
be prepared to spend the money on the proper stuff, its not worth getting it all cheap then finding your engine just blows as soon as you give it some welly,
also don't forget you need a fuel regulator, turbo fuel pump and modified fuel tank..
just noticed, that list of stuff looks scary!
dont be put off, it will be worth it!!!
DAN
Posted 28 October 2004 - 09:15 PM
Yeah I am still learning at the moment but my knowledge is getting better(so I hope). Best way to learn is actually doing it. I will try not to take shortcuts as I have heard that turbo motors like blowing up. I just want a turbo mini so much.
By the way I would also like the dump valve whoosh. That means that I would have to upgrade the dump vale doesn't it?? Expensive or not??
Posted 28 October 2004 - 09:24 PM
the tank needs a fuel return pipe put in nice and high up so that the fuel not used can go from the regulator back to the tank.
the plenum chamber will need modifying to fit a dump valve, its not too hard to do i don't think, i havent done it yet though! still building my turbo (998 turbo, just to be different!
turbo minis don't like to blow up by the way, as long as you build it carefuly and make sure you ROLLING ROAD IT! (very important) it will all be good. they only blow up when they are poorly buit, badly set up or running too much boost for the engine spec to take!
i cant wait to hear that dump valve go off on my mini!!!
DAN
Posted 28 October 2004 - 09:31 PM
A 998 turbo will be mean. I love the idea of a dump valve on a mini, so different. Would shock people a bit as well.
Thanks again for all the info. I just can't wait to ge tthe engine and start doing stuff to it.
Posted 29 October 2004 - 09:29 AM
Check the engine when you get it, if you're really lucky it may not even need to be rebored. The stock 1275 MG Turbo pistons are a good bit of kit, and going from 1275-1293 will gain little in terms of power.
Fitting a dump valve is easy, just make sure you block the "overboost spring" in the plenum. http://www.turbo-min...9320/index.html
Phil. :grin:
Heere's a picture of a centre main strap for you. :wink:
