Ok so i replaced the head gasket after finding mayo under my oil cap. A week later i still have mayo! I just use my car to goto work, wich is 5 minutes away. So in total its used about 10 minutes a day. Could this just be the reason why i have mayo?
Still got mayo
Protarmic
, Apr 06 2007 03:44 PM
7 replies to this topic
Posted 06 April 2007 - 03:44 PM
Posted 06 April 2007 - 03:46 PM
short runs - yup
Posted 06 April 2007 - 04:01 PM
get a rocker cover cap that hase a inbuilt breather ?
Posted 06 April 2007 - 04:06 PM
Let the engine warm up fully and give it a good run once in a while.
Posted 06 April 2007 - 04:10 PM
Agreed mate, you ned to give the car a good run or condensation will build up causing white mayo.
Prudhoe! I was born and bred in Morpeth!
BM
BM
Posted 06 April 2007 - 06:49 PM
i had the same thing (but my head was blown) so i replaced the head and gasket, changed the oil, got mayo within a week.... changed oil again... mayo within a week again.... removed head, gasket good but replaced anyway and changed oil and flushed through.... mayo a week later again!!!!! only on the rockers though none in the sump!!!! gotto get a vented cap.
Posted 06 April 2007 - 07:17 PM
as has been said, you need to give it a good run. at least once aweek give it a good blast, if you can find a dual carrage way so you can really get the engine nice and warm all the better.
remember you will still have some of that white cr*p in the engine, it will take a few oil changes to get rid of it.
Posted 07 April 2007 - 05:05 PM
Like everybody else says, try and get hold of a vented rocker box or vented cap and go for a 100+mph blast at least once a month (on a private road because the speed limit is 70 and you wouldn't think of breaking that)
