Post holiday non-starter
6 replies to this topic
#1 TheFunkyGibbon
TheFunkyGibbon
  • 162 posts
  • Local Club: Non yet...
Posted 09 April 2007 - 02:16 PM
Afternoon all...
I just got back from my jolly holidays (3 weeks in the sun) only to find that the mini is a non-starter.
When the key is turned I can hear a sound like an old typewriter, coming from the starter motor end of the engine bay.
The battery meter on the dash is showing around 8v before i turn the key, then it dips towards 1v when i turn the ignition.
Any clues on the problem + any ideas on asolution???
Cheers,
FG.
#2 scottyegg
scottyegg
  • 394 posts
Posted 09 April 2007 - 03:43 PM
is the noise like a click ? when you turn the key into the 3rd position ?
+ has your car got the solinoid on the drivers side wing ? or on the starter motor ?
might be a bad earth !
#3 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 09 April 2007 - 04:50 PM
Do you have an alarm fitted to the car and was it switched on?
Alarm left on for three weeks without moving the car = flat battery :(
The solution is to charge the battery. Next time you leave the car for this long, remove the battery
Edited by Mini Sprocket, 09 April 2007 - 04:52 PM.
#4 Gazman
Gazman
  • 148 posts
Posted 09 April 2007 - 08:20 PM
Sounds like a flat battery to me...
#5 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 09 April 2007 - 08:26 PM
FG you still at the same place??
Could pop down and have a look
#6 Doooeks
Doooeks
  • 39 posts
Posted 09 April 2007 - 08:55 PM
My money's on a flat battery.
When you turn the key, you send 12V to the switch wire of the solenoid. The solenoid closes (with a click) which virtually shorts the battery across the Starter motor coil.
If your battery is good, oodles of current flows and everything's fine, starter turns & Engine starts.
If your battery is low, the battery can't supply enough current so the voltage drops.
When it drops too low to hold the solenoid on, it switches off (click), opening the circuit through the starter and the voltage rises again. When it gets high enough, the solenoid engages again (Click) and the voltage drops...
When it drops too low to hold the solenoid on, it switches off (click), opening the circuit through the starter and the voltage rises again. When it gets high enough, the solenoid engages again (Click) and the voltage drops... etc.
As this happens very quickly, the clicks sound like a rattle (or a typewriter) :(
#7 TheFunkyGibbon
TheFunkyGibbon
  • 162 posts
Posted 10 April 2007 - 10:52 AM
For those of you betting on the problem.....
Called my dad to nip down with some jump leads....rolled it back so he could get the leads on.
Thought i'd have one more try before jump starting it and Hay Presto started first time.
I think the starter motor had stuck for some reason, then when I rolled it for a short distance (in gear) it's somehow freed it up.
Either that or it was just unhappy with me leaving it on it's lonesome in works car park for three weeks.
For future reference I'll leave the battery on trickle charge next time as I now have a garage for it to live in :P
Cheers for the suggestions all.
FG.
