Whats wrong with my Mini!!!
11 replies to this topic
#1 Bigbluey
Bigbluey
  • 26 posts
Posted 10 April 2007 - 07:14 AM
Ok where do I start, My Mini is 1330 and It has a single carb with k&N on it. My car also has a bonnet scope which might be why the problem has occured. Everytime I take the car out in a cold morning it runs like C**p. It stutters really bad untill you drive around for a good 10mins then it stops. But the other day when I was driving home from work it didnt get better at all it got worse, to the point where it wouldnt even move it was just miss firing. It was also raining during the day so could it be water that got into the carb? I got towed to the garage by a mate and took out all the sparks, they were like completly black. After a good clean the car would run good enough to get home but it is still running really bad with constant missing (whats the problem?) The coil on the car mite even be the standard 850 coil, could this also be a factor? Please if anyone could help me that would be great!!!
Thanks Heaps
#2 Bigbluey
Bigbluey
  • 26 posts
Posted 10 April 2007 - 07:24 AM
Thanks Heaps
Here is a pic of the engine if it helps
#3 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 10 April 2007 - 07:30 AM
Well, normally if someone is having difficulties with misfires in damp conditions I'd say to check the distributor cap and make sure that isn't getting damp/condensated.
If you suspect that there is a lot of water getting under the bonnet into the carb area, I'd also do something about sealing that.
#4 camp freddy
camp freddy
  • 3,696 posts
Posted 10 April 2007 - 08:01 AM
take the distributer cap off in the morning and see if
it has condensation in it,spray the inside with WD or
similar moisture dispersal spray, change the disi cap if it is
old just incase it is cracked. also spray the leads they may be
stray arcing causing a miss fire, i'd change the plugs and condeser
aswell, best to change things in turn then you will know what
the problem was.
Edited by camp freddy, 10 April 2007 - 08:06 AM.
#5 camp freddy
camp freddy
  • 3,696 posts
Posted 10 April 2007 - 08:08 AM
is your inlet manifold water heated ?? if not you could be getting slight
carb icing.
Edited by camp freddy, 10 April 2007 - 08:08 AM.
#6 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 10 April 2007 - 09:12 AM
sounds like it needs a good proper service... and is running too rich also, hence the sooted up plugs. Head's probably coked up too.
Edited by Retro_10s, 10 April 2007 - 09:12 AM.
#7 Bigbluey
Bigbluey
  • 26 posts
Posted 10 April 2007 - 10:32 AM
So it will have nothing at all to do with the old coil? I took it into the garage for a good service like a month ago. They didnt change the leads or sparks tho...Is this what will be required as far as a service goes?
#8 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 10 April 2007 - 10:47 AM
It sounds like the coil breaking down, only way to see is to change it or do the test in the haynes book.
#9 Bigbluey
Bigbluey
  • 26 posts
Posted 11 April 2007 - 10:19 AM
Does anyone else know what it could be? I am going to try it all on the weekend with a bit of luck. Thanks everyone
#10 Sammy D
Sammy D
  • 977 posts
Posted 11 April 2007 - 12:41 PM
Check your points as well. I had a similar problem to you.
Turned out to just be points and condensor.
#11 Bigbluey
Bigbluey
  • 26 posts
Posted 12 April 2007 - 10:57 AM
thanks heaps everyone. I will have a look in the weekend
#12 camp freddy
camp freddy
  • 3,696 posts
Posted 12 April 2007 - 06:09 PM
any joy ????????????
