Remote Gear Change Removal
5 replies to this topic
#1 RammsteinMini
RammsteinMini
  • 70 posts
  • Local Club: The Mini Clan
Posted 10 April 2007 - 07:09 PM
as i'm going to be removing henry's engine, i've been preparing him. good old haynes manual says to drift out the pin on the gearchange selector rod...but there are 2 pins! and neither budge when hit with a big hammer and punch! anyone any ideas for the best way to remove em so i get the linkage off? :P everything else is done bar this, tis rather annoying!
cheers
RM
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 April 2007 - 07:44 PM
Get a bigger hammer, or bigger arms.
#3 vasi
vasi
  • 897 posts
  • Local Club: Minis 'n' Oatcakes
Posted 10 April 2007 - 10:39 PM
Lump hammer works best. Select a gear which allows for a sideways thrafting of one of the pins.
#4 Nic
Nic
    Formally known as jonesy!
  • 1,218 posts
Posted 10 April 2007 - 11:35 PM
isnt one of them a bolt??
#5 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 11 April 2007 - 06:56 AM
Use the correct sized drift (from memory I think I use a 3mm one) and give the pin a good smacking!
Can't remember which gear the car needs to be in, but I think it may be reverse, that'll give you the clearance to drift the scroll pin through.
Do a search on here and you'll find out which gear it needs to be in and also the size of the drift that's needed for definite.
#6 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 11 April 2007 - 06:59 AM
Ooh, and by the way, it's called a rod change on your car, not a remote change, the remote change was fitted to earlier cars and has an alloy casing that extends from the gearbox back to the gearstick. :P
