Splitting gearbox and engine.
Posted 11 April 2007 - 12:15 PM
Thanks, Chris.
Posted 11 April 2007 - 12:32 PM
My engine will be out of my car by friday, what is the best sequance for splitting the gearbox and engine?
Thanks, Chris.
Get an engine stand to start with...
attach engine to stand
Drain fluids.
remove bell housing, starter motor, then flywheel, followed by the transfer case
turn engine over ( gearbox uppermost )
remove all bolts and two nuts
Lift and separate
Posted 11 April 2007 - 12:58 PM
I dont have a engine stand so ill have to split it on the floor. How do you remove the transfer case?
Thanks, Chris.
Posted 11 April 2007 - 01:00 PM
Posted 11 April 2007 - 01:03 PM
Once flywheel is off, undo all the bolts and hit with soft faced mallet...
Ok, thanks. Ill split it this weekend.
Thanks, Chris.
Posted 11 April 2007 - 01:05 PM
Posted 11 April 2007 - 01:08 PM
Also going to check the idler gear & primary end floats.
May as well paint the block whilst it's out too.
Better than new when finished.
Edited by markelvin, 11 April 2007 - 01:08 PM.
Posted 11 April 2007 - 01:21 PM
Chris.
Posted 11 April 2007 - 01:42 PM
