Fuel Consumption and Rolling Road
Posted 13 April 2007 - 09:02 AM
I know i need a rolling road tune-up, but is it purely the wrong/worn needle/jet that is causing my issues or are there other factors? I have set my timing to 5 BTDC, have had the colourtune on it and it is a nice bunsen blue flame at idle and slow acceleration but under any medium to heavy acceleration its just yellow which leads me to believe that the needle is totally wrong or the jet worn etc?
So with regards to Rolling Roads, how important is it to go to a mini specialist and why? Because i only really have Mini Speed around here and you will only ever get on thier RR during the week (when i work obviously). Is it simply to do with the availablity of needles and other parts or will any rolling road place be able to accomodate a mini?
Posted 13 April 2007 - 09:09 AM
Moved to Technical...
Posted 13 April 2007 - 11:43 AM
And what will the differences be between taking to a mini specialist and a non mini specialist be?
Cheers for any advice...
Posted 13 April 2007 - 11:44 AM
Posted 13 April 2007 - 12:05 PM
Have you ever had your daughters mini on a RR and if so where did you take it?
Posted 13 April 2007 - 12:13 PM
If your like me (lead foot) then the fuel consumption is C**p no matter what you due.
Posted 13 April 2007 - 12:41 PM
May i ask what mpg you consider c**p?
Posted 13 April 2007 - 12:45 PM
You may of course ask, i would describe it as spirited, but definately not planted at all times.
My mpg is always c**p. More money in the tank means less in the wallet. Damn student life.
Posted 13 April 2007 - 01:57 PM
Posted 13 April 2007 - 02:01 PM
No, but I understand there is a good place in Molesey somewhere. I probably won't get it done unless it is really bad. I need to fit a new main jet and give the carb a good clean, then I will get it done on a gas analyser. It is doing 30+ mpg at the moment, performance wise it is a bit gutless, which actually suits me with her license only being 3 weeks old!!
Posted 13 April 2007 - 02:04 PM
I do about 100 miles to £10 and I run a 998, 12G295 head and twin 1.25" carbs, 1.75" peco
That's about 43 to the gallon!!!!!!! Not a lot wrong with that!!
Posted 13 April 2007 - 02:05 PM
The "perfect" needle will differ from engine to engine and even 2 engine of identicle spec may require different needles... though you may have ideal mixture at various points along the needle you may also have blips of idle and rich along it.... with a rolling road they can compare fuel air mixture throughout the rev range, select a needle that is slightly lean across the board and then file bits off it until it's near on perfect.... but this also takes time and a few attempts to get right... also, file too much off and it's too rich and you cant ad bits back on..
Posted 13 April 2007 - 02:13 PM
So basically, yes you do need to take it to a Mini Specialist
It is well worth taking a day off to get it done
Posted 13 April 2007 - 03:29 PM
