Have I knackered my hub?
8 replies to this topic
#1 OllyD
OllyD
  • 447 posts
Posted 13 April 2007 - 11:22 PM
Ok, this thread will benefit greatly from some pictures which I'll add over the weekend but:
I got a bit overzealous when removing my wheel bearings from the hub this week, and think I may have caused some small nicks in the inside wall of the hub where I've caught it with my punch. They're quite small, and not deep, and are on the wall where the outer races would touch.
Is it likely this had made the hub unusable, or is this not a problem?
#2 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 13 April 2007 - 11:33 PM
Is this the same hub as the bolt is stuck in? If so why not get another hub?
#3 OllyD
OllyD
  • 447 posts
Posted 13 April 2007 - 11:45 PM
Monetary concerns. I'm having to sell non-vital organs just to afford an engine.
#4 OllyD
OllyD
  • 447 posts
Posted 14 April 2007 - 06:27 PM
Ok guys, here's some pics for a bit of clarity.
#5 mini13
mini13
  • 3,811 posts
Posted 14 April 2007 - 06:37 PM
They are bad in respect that they will cause issues getting the outer part of the bearing in, if you a have a dremel or similar dressing the bits that stick out so they are flush will be fine.
When you put the outer races in use a bit of bar, 1/2" dia is about ideal an be very patient, a ligt tap in two or 3 places and gradually work it in until it touched the rased bit in the hub.
#6 OllyD
OllyD
  • 447 posts
Posted 14 April 2007 - 07:33 PM
So if i can still get the outer races in, it won't cause any problems after that?
#7 Major Burkenshaw
Major Burkenshaw
  • 638 posts
  • Local Club: Brighton mini club
Posted 14 April 2007 - 10:10 PM
The grooves will only impeid the fitting of the outter race for the bearings, if you do the above you should have no problems with the bearings/hubs
#8 Big_Adam
Big_Adam
  • 7,435 posts
Posted 14 April 2007 - 10:47 PM
I buff it out with some 360 or 1000 odd grade wet dry. Thats just me tho.
#9 jonny d
jonny d
  • 1,148 posts
Posted 15 April 2007 - 10:01 PM
IM with them take the burr off and they will go again ;)
