steering column bushes
7 replies to this topic
#1 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 16 April 2007 - 06:00 PM
right, just got the top and bottom steering column bushes from mini spares today (thanks Rocket), which means i can get the cooper finished and book the MOT.
just wondering, are you supposed to put any lube/grease on these or just pop them in dry ???
they are the plastic type.
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 16 April 2007 - 06:04 PM
Right,
Top (plastic) one you grease. Same with the bottom plastic one (later model cars). IF you have a lower felt bush then it need to be soaked in oil for 24 hours beforehand.
#3 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 16 April 2007 - 06:43 PM
cheers, yes their both plastic. i have done the felt ones before with the oil.
whats the best grease to use? normal stuff, copper, KY ;) etc.
also forgot to ask...
thermostat gasket.... fit dry or some kind of sealant ??? (i'm really not an Anorak when it comes to taking the engine apart ;) )
#4 Big_Adam
Big_Adam
  • 7,435 posts
Posted 16 April 2007 - 06:56 PM
Thermostat. I left mine as is, no sealant. Wouldn't suggest it. A smear of something might be a good idea is all.
As for the grease. I used regular stuff on my steering column, if it's good enough for ball join then it's good enough for the column.
#5 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 16 April 2007 - 08:15 PM
cheers ;)
#6 AlexM
AlexM
  • 1,302 posts
  • Local Club: NMOC, ECMC
Posted 16 April 2007 - 08:56 PM
I used some hermatite yellow on my thermostat housing when i fitted it on sat. Make sure you put some sort of anti seize on the studs! You do not want them seizing!
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 April 2007 - 09:51 PM
Graphite grease should be used for the column bushes, the grooves inside the bushes need to be filled with grease and the bore coated.
#8 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 16 April 2007 - 10:12 PM
Aha, we got loads of that at work ;)
thanks guys.
