Roll cage and back seats
19 replies to this topic
#1 zeroasylum
zeroasylum
  • 378 posts
Posted 17 April 2007 - 09:06 PM
Ok i want to fit a safety devices roll cage but still need the use of my back seats. So here are my questions.
I will be fitting cobra classic seats. Can I still use my normal seatbelts or do I need harnesses?
Can I use my back seats as normal with the cage?
Zeroasylum
#2 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 17 April 2007 - 09:09 PM
depends whether the cage has a diagonal across it but if not then the rear seats will be fine and yeh you can still use your normal seat belts with the new seats :-
#3 zeroasylum
zeroasylum
  • 378 posts
Posted 17 April 2007 - 09:30 PM
Is it dangerous with normal belts in the front like hitting your head off the cage or will it be ok.
Zeroasylum
#4 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 17 April 2007 - 09:32 PM
how would you hit your head on the cage? its behind you!
but no they work fine my mate has them
#5 whiskymac
whiskymac
  • 247 posts
Posted 17 April 2007 - 09:35 PM
Only if its a half cage, if its a full cage then there will be bars above and in front of you. Personally I wouldnt like to drive a car with a full cage unless i had good buckets and harnesses
#6 Matrix
Matrix
  • 589 posts
Posted 17 April 2007 - 09:39 PM
I had a removable diag in one a few year back so if I needed the back seat I just took it out! came in quite handy realy
you could tell when it was in though if you hammered it into a corner :-
#7 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 17 April 2007 - 09:41 PM
does it handle better through the corners with the diagonal then?
#8 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 18 April 2007 - 11:48 AM
basically, yes! The diagonal helps stiffen the car massivley over the non-diagonal rear cage!
I have not had rear seats in any onf my last 6 mini's, it's much better knowing you can tell people that you only have 2 seats as your "friends" don't increase when you have car because they know you can't be a taxi for them!! lol
#9 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 18 April 2007 - 11:52 AM
harnesses also equal no rear passengers.
#10 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 18 April 2007 - 11:54 AM
lol awesome, i already tell everyone its a 2 seater so i dont become a taxi. soo.. diagonal it is then, what cage would you suggest?
#11 minislapper
minislapper
  • 1,957 posts
Posted 18 April 2007 - 11:57 AM
And don't forget to declare it to your insurance company!!
#12 zeroasylum
zeroasylum
  • 378 posts
Posted 18 April 2007 - 03:28 PM
Insurance is fine they view a roll cage as a cosmetic change to the car. Anyone recommend some seats that are not those lage cobra buckets. Was thinking of some cobra classics any other recommendations that are suitable with a roll cage. Remember I still want to use my back seats.
Also someone on the forum mentioned you can buy 3 point harnesses with pretensioners. Does anyone know where.
zeroasylum
#13 cornflakes5210
cornflakes5210
  • 258 posts
  • Local Club: sws south wales scoobys
Posted 18 April 2007 - 08:19 PM
well i got cobra classics and a full roll cage and u can fit someone in the backseats sideways
because the seats lean back leaves you with hardly any room. also one thing i found with the cage if your going to fit a dash do it first because i welded mine in then done the dash. which windows have to come out and all that kaffufle just thought id tell you that aswell.
#14 zeroasylum
zeroasylum
  • 378 posts
Posted 19 April 2007 - 09:51 PM
Just another quick question can you use standard seatbelts with cobra classics or will it just not work with bucket seats.
Zeroasylum
#15 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 19 April 2007 - 11:19 PM
think it works to a degree but the seats are usually so laid back the shulder strap wont erach ur shoulder properly, better to have buckets with harnesses, even if they are jsut the same thickness as the standard seatbelts, they'll sit better in the car.
