Window Mechanism Sealer
Posted 22 April 2007 - 08:49 AM
Thanks in advance
Ben
Posted 22 April 2007 - 09:31 AM
Posted 22 April 2007 - 09:50 AM
If you mean the stuff which holds the regulator channels to the bottom of the glass I would use some sort of glazing sealant like used to fix in place modern car windscreens
cheers
Posted 22 April 2007 - 11:21 AM
The stuff I used to hold/seal the regulator to the inner door skin was called Dum Dum
cheers
I need the stuff that goes between the requlator and the inner door skin so it looks like Dum Dum is the stuff I need
Thanks guy's
Posted 22 April 2007 - 01:52 PM
Edited by Dan, 22 April 2007 - 02:32 PM.
Posted 22 April 2007 - 02:11 PM
good solid bond but minimal amount of flex so it wont crack and break apart.
Posted 22 April 2007 - 02:31 PM
Posted 23 April 2007 - 04:55 PM
That's it, Sicaflex. I was trying to rmember the name of it. That's the correct stuff.
Hmm I will have to look for that, although have done a search on google and only comes up with sellers in the US
Posted 23 April 2007 - 06:59 PM
and i can tell you, you won't get them apart again without damage
to the winder mechanism!
Posted 23 April 2007 - 10:19 PM
