mini neon engine spec
Posted 08 November 2004 - 10:04 PM
edit - if it helps its a mark 5
Posted 08 November 2004 - 10:22 PM
Posted 08 November 2004 - 10:42 PM
Posted 08 November 2004 - 10:45 PM
Posted 08 November 2004 - 10:58 PM
Posted 08 November 2004 - 11:45 PM
STage one kit will give a MAX of 20% power, 12% torque increase, and only then if your lucky. Other advised mods are weather shield if you have issues in the wet, electronic ignition, U/L head either a modified mini, or from a metro, then stage 1 kit for more power. All mods should be stated under insurance, even if they do not increase performance.
Service and check over doesnt really mean much as tolerances are so odd, and balancing is therefore odd, so engines can easily produce up to 10% different figures from those stated by manufacturer, who'll usually state the best figures they can get away with.
Oooh, is it carb or injection? i'm unsure for 91...! the above may all be utter rubbish!
Dave
Posted 09 November 2004 - 12:28 AM
There are no genuine injected 998's.
Posted 09 November 2004 - 08:39 AM
Posted 09 November 2004 - 05:01 PM
oh and dan good idea il check if a catalyst is fitted, but because its a 1991 i reckon its not, or so i hope :fear:
thanks - lewis
edit - would a stage 3 head be ok to put on a 998cc?
Posted 09 November 2004 - 06:57 PM
The cat was only an option on this car, so you are probably right to think you don't have one. But if you do, the carb type cat was rubbish and robs around 5bhp accross the range so you may want to think about losing it but there could be emissions legal issues if you do.
Posted 09 November 2004 - 07:26 PM
Also as far as i know you dont need a cat on any car (or engine) manufactured before 1992. My city of the same year as yours had a cat fitted and I just junked it!
Posted 09 November 2004 - 07:54 PM
Posted 09 November 2004 - 08:08 PM
I'd try the stage 1 kit first (Minispares kit is the best IMHO) as it is by far the best BHP per £ performance upgrade for the Mini, and add the head if you still think you want it. The other good thing about the stage 1 is that most insurers don't mind them, whereas a performance head is almost certain to increase your premium. Both upgrades will need a proper rolling road tuning session too.
Posted 09 November 2004 - 09:24 PM
Posted 09 November 2004 - 09:35 PM
it flew
it would destroy 1275's
