Electronic Speedo
Posted 27 April 2007 - 06:16 PM
My first question is, can you get these in 12v so they will turn on when the ignition is on? if not how would the be poseders, because i cant see the little watch battery lasting long, as i would have to leave it on constantly because i will be mounting it inside an old gauge...
My second question is, how would you mount it in place i know it works with a magnet and a sensor, but how would this work? do i just mount the magnet on the wheel and then the sensor on to where ever i can find that looks suitable?
And finally, surely because some wheels are different sizes the travel of the magnet will be different so how does the speedo work properly?
Posted 27 April 2007 - 06:30 PM
you wont find a bike one in 12 v as they are meant for a bike and so run off the watch style batteries may get a motorbike one thou?
mounting is basically as you have put
the issue with different wheels is covered by the settings on the unit which you can alter for bike wheel sizes
Posted 27 April 2007 - 06:37 PM
From what i have read and heard it seems quite easy to do, but im just woundering why not many people have done the conversion, as from the minis i have had so far none of the speedo's are very accurate. and from other mini owners i have spoken to their speedo's arent very accurate either.
Posted 27 April 2007 - 06:39 PM
Mike
Posted 27 April 2007 - 06:54 PM
Posted 27 April 2007 - 07:11 PM
Also, if you solder wires to the watch battery holder in the rear of the unit, and hook them up to a a single AA battery holder, you shouldnt have any problems with batteries! lasts much longer, and easier to change!
Posted 27 April 2007 - 07:19 PM
Posted 27 April 2007 - 07:27 PM
Posted 27 April 2007 - 07:29 PM
Posted 27 April 2007 - 07:34 PM
Posted 27 April 2007 - 07:36 PM
Posted 27 April 2007 - 07:41 PM
http://cgi.ebay.co.u...1QQcmdZViewItem
Posted 27 April 2007 - 07:43 PM
Posted 27 April 2007 - 07:44 PM
just find a constant supply as used by stereos and clocksI guess i could use a resistor but i dont really know much about how to work out what resistance values to use etc.... just a thought but if i bypassed the on/off switch, that would mean that its constantly on so i could have it wired in off a resistor and then it would turn on/off with the cars ignition.
Posted 27 April 2007 - 07:45 PM
Bicycle speedos include memory bits to store your odometer readings, units, and scale factors. If you interrupt the power you'll have to reprogram it every time you power up.
The solution is to buy a Sigma bicycle computer. It's powered by a common Lithium coin cell (CR2032 ?) which will last several years ( I think the manufacturer says 3 years). The display automatically wakes up and goes to sleep. The remaining electronics are always powered by the coin cell to retain the program variables.
Sigma units are probably the best speedo choice because they can read and display high speeds. Many bicycle computers can't display high-speeds... when was the last time you saw a bicycle go 65 mph or more? Sigma speedos also allow you to VERY accurately program the scale factor (this matches your speedometer to your tire size very accurately). Lastly, Sigma units allow you to enter an odometer value. You don't have to start with an odometer that reads zero (0) miles, you can set it to match your exiting odometer.
To install the speedo you'll need to extend the wire leads between the display and the pickup (which is a reed switch). You'll need to mount the magnet to a rotating component on the drivetrain. I suggest the OD of the inner driveshaft joint. You'll have to fabricate some form of mounting bracket for the pickup so it is close to the magnet and doesn't vibrate much. The bracket needs to be fairly stiff.
An issue with bicycle speedometers is that they have no internal lighting. Your idea to mount the unit in a Smiths 52mm housing would work as it will allow illumination from the back. However, mounting it like that will make battery replacement difficult and will make it impossible to access the pushbutton switches that toggle between display modes such as odometer, trip meter, fastest time, etc.
Google Sigma and use other keywords like motorcycle. The Sigma BC800 (which I used) is a common choice of motorcycle owners who want a digital speedometer.
EDIT: See these links for a little more Sigma info.
http://www.geocities..._toys/bc80.html
http://www.strangely...comp/index.html
http://www.kartingte...om/tech/mph.htm
Edited by dklawson, 27 April 2007 - 07:59 PM.
