pocketing a 1275 head
Posted 30 April 2007 - 01:48 PM
Posted 30 April 2007 - 02:05 PM
hello guys am new to the mini scence and want to keep my standered 998 block so am getting it all rebuilt but i have heard about u can pocket a 1275cc head so the 998 has more power? how does this work? and how much?can use a race cam and like a stage 4 head 1275 head on a 998 bottom end. just really confused sameas the rockers what are they reeally for and do u need them. am goin to build a fast road/ race 998 engine but dont want to spend loads so dont know were to start
hello mate, bit of confusion here....
Yes you can fit a 1275 head to a 998, However i'm not sure you understand pocketing:
You don't pocket the head, Pocketing is done to the engine block. When you fit a 1275 head to a 998 block you have to remember that because the bores on 988 block are smaller than the 1275's, it means that when the valves open they will hit the top of the block, this can cause lots and lots of damage to the engine.
In order to overcome this, small pockets can be ground into the edge of the bores of the block to allow the valves to open, the valves will travel down and into the pockets safely. This can be done with a dremel. the best way to do this is to put some blue tack around the engine bores. Then lower the head onto the block. Then turning the engine over slightly will open the valves. The valves open and make a mark in the blue tack, this is your template to cut the pockets.
You must also remember that by fitting a 1275 head to a 998 block, you are already fitting the equivalent of a stage 3 988 head onto it! there are loads of cams around, The Swiftune SW5 is a very good upgrade giving bags of torque and nice on emmissions too.
Rockers.... if i'm correct, High lift rockers enable the Valves in the head to open more (hence letting through more fuel/air mixture), so fairly significant gains can be had... if set up correctly, often hig lift rockers also have a feature called 'roller rockers' these claim to dramtically reduce side loading on the valve stems, especially good at High RPM, which is what you'll be looking at in a revvy short stroke 998.
Posted 30 April 2007 - 02:07 PM
I would suggest you need to learn more about the engine before you try to build it and also learn more about what you want from it and how Minis perform and drive. Asking questions like this is a good start but also feel free to search our archives for threads you may find useful or read the FAQs. There's an awful lot of knowledge on this site and there are also many good books available such as David Vizard's 'Tuning Bls A Series Engine'.
Welcome.
Posted 30 April 2007 - 02:09 PM
Posted 30 April 2007 - 02:28 PM
Edited by Dan, 30 April 2007 - 02:29 PM.
Posted 30 April 2007 - 02:29 PM
Posted 30 April 2007 - 02:45 PM
Not sure as I've never seen the need to do it... may aswell save the money and buy a 1275...
Posted 30 April 2007 - 02:57 PM
I was distracted by considering whether or not I should mention in a certain thread about wheels that Hillman and Triumph weren't BMC companies......
bah
Posted 30 April 2007 - 02:59 PM
Posted 30 April 2007 - 03:09 PM
Posted 30 April 2007 - 03:11 PM
Posted 30 April 2007 - 03:13 PM
and if you think it would be cheaper on the insurance, think again !
Posted 30 April 2007 - 03:22 PM
Posted 30 April 2007 - 03:29 PM
there are some very nice high powered small bores out there, but IMO, it's a pounds per HP issue.... you get more for you heard earned when starting with a large bore..
Posted 30 April 2007 - 03:53 PM
