taking a 998 apart
Posted 01 May 2007 - 05:22 PM
ive got an old 998 that i started to take apart to have a look what goes where and how it works, and them hopefully i will have a go at rebuiding it.
i have taken off all the ancilleries and obvisuos outer bits
but ive got a bit stuck.
how do you get the head off the block?
it is really stuck.
is there a special way about doing it?
do you have to disconnect the con rods from the rockers?
thanks
Posted 01 May 2007 - 05:27 PM
As for the head. Take out all the studs and give it a squirt of oil down the stud holes. Hack the bypass hose too. Then get a mate to hold a bit of wood on the side of the head and crank it one.
One of two things will happen.
1)Head comes off, flys across the room and smashes into the floor.
2)Bugger all happens.
Oh wait, con rods....do you mean push rods? Take the rockers off then you can pull them out.
Posted 01 May 2007 - 05:32 PM
"Then get a mate to hold a bit of wood on the side of the head and crank it one. "
what do you mean - soz - havin a blonde moment
Posted 01 May 2007 - 05:47 PM
Posted 01 May 2007 - 05:49 PM
Is this engine a total spare? Just a learning exercise kinda thing? Prolly the best thing to do is remove the studs to be honest. Wind a couple of nuts onto the stud, tighten the two together, wind the bottom nut up to the top one and remove the stud.
Posted 01 May 2007 - 05:51 PM
If yer head is stuck, check the head studs for a build up of corrosion. If the head won't move at all, you can do one of several things. You 'could' give it a whack with a mallet,
Sorry, my way is the brute force and ignorance way of doing it.
Posted 01 May 2007 - 05:53 PM
Adam my friend, there is nothing wrong with the occasional bit of BFI!
Posted 01 May 2007 - 06:04 PM
where can i crank it over from, the timing chain end? the big nut?
as it dont hav any clutch assembly on.
Posted 01 May 2007 - 06:10 PM
Posted 01 May 2007 - 06:11 PM
If that doesn't help, then try MMM and Adam's advice.
I'll take that as a compliment.
Posted 01 May 2007 - 06:12 PM
so i will take the whole rocker assembly off - including valve springs?
then lift out the push rods
and the head should come free???
thanks
Posted 01 May 2007 - 06:22 PM
Posted 01 May 2007 - 08:05 PM
Not being nasty but it goes through the whole process of disassembly in quite comprehensive detail and is a pretty much must have for anyone doing anything to their car.
Posted 01 May 2007 - 09:45 PM
Posted 01 May 2007 - 10:06 PM
