Wheel alignment spec ?
2 replies to this topic
#1 Mulky
Mulky
    Just On Tickover
  • 8 posts
Posted 07 May 2007 - 05:18 PM
Does any one have OR know, the optimum alignment specifications for a 1988 mini running of 13"/J7.
As i have fitted HI-LO's (lowered 10mm on the front and 40mm on the rear) and adjustable front lower arms, so ideally i need the toe and camber setting, also i could do with the castor measurment range as i suspect that is out of tolarenes (i may fit adjustable tie rods if so).
Thanks in advance, an advice is greatly received. :genius:
#2 icklemini
icklemini
  • 2,982 posts
Posted 07 May 2007 - 09:57 PM
ooo big wheels, have setup loads of these as to be honest the owners thought that they drove like kak with the standard stuff - and indeed they do.
well, the settings i aim for is:
Camber - straight up, tracking - toe out 1/16" max, castor - 6 degs matched perfectly side to side.
at the back, again camber straight up, and toe ideally parallel or at most 1/16" toe in.
you will need the tie rods adjustable, and get decent rubbers in there..
with the hi-los fitted it is worth getting the corner weights setup.
hth,
Dave
#3 Mulky
Mulky
    Just On Tickover
  • 8 posts
Posted 08 May 2007 - 07:28 PM
Thanks very much for the info, Just mangaed to get hold of second hand pair of adjusable tie bars.
:genius:
