Internal fuel/brake lines.
Posted 13 May 2007 - 02:58 PM
I want to run the fuel lines and the brake lines inside the car. I want to clean up the underneath for many reasons.
Are there any legal issues I should know about? Or safty issues?
I was thinking of using braided lines (tougher the better) and maybe putting them in a pipe to protect them (maybe over kill)
Mr Benn
Posted 13 May 2007 - 03:07 PM
Posted 13 May 2007 - 03:37 PM
I can understand it being safe for passing over things, but is it legal? If so is there any regulations?
Mr Benn
Posted 13 May 2007 - 03:55 PM
If you really want to do it then there must be no joints of any kind in the line inside the passenger cabin (certainly for the fuel, don't know about the brake although the fluid is nearly as flammable as petrol). And braided lines are out, yes tougher the better as you say but steel braid over nylon is not tougher than solid steel or copper. It must be solid line and one continuous piece.
Personally, I think this is a really bad idea. It is far more likely that a passenger will stamp on any lines inside the car than it being torn off the underside, unless you aim for all the kerbs of course. If you are really worried about it (like the billions of people around the world driving cars with fuel lines underneath aren't) then you could consider fitting the protector plates from an MPi Mini which cover the lines where they are most vulnerable.
Posted 13 May 2007 - 04:01 PM
Mr Benn
Posted 13 May 2007 - 04:13 PM
That's not neccesaraly true, not if you have the correct piping and protection.It is not safer by any means to have the petrol inside the car with you.....
Posted 13 May 2007 - 04:20 PM
I'll tell my mate in California who had both his legs burned off in a crash while he was still concious. I'm sure it will be a comfort to him.
In my opinion, keep the fuel out of the cabin and fit an innertia switch. Every time.
Posted 13 May 2007 - 04:25 PM
Anyway we're straying, i guess Yeti views on this subject are split.
Edited by DJH MINI MOTORSPORT, 13 May 2007 - 04:30 PM.
Posted 13 May 2007 - 04:36 PM
Posted 13 May 2007 - 06:15 PM
I think i will run them Im a pipe covered with heat proofing next to the exhaust. Im moving the gearchange inside........ but the heat proofing isn't that good from what I've been told.
I always keep a fire extinguisher in the car. But after what you said Dan, about your friend (I hope he is okay now). Im really going to have to sit down and work this out 100%. And it does't have to look good if you can't see it.
Cheers for the help guys. If I do move the brake/fuel lines, I'll take photo's and make a thread for it.
Mr Benn
Posted 14 May 2007 - 12:02 AM
samwell
Posted 14 May 2007 - 12:34 AM
not ALL of them do...Considering ALL racing cars have the fuel lines inside the car
