wipers
5 replies to this topic
#1 od161
od161
    Just On Tickover
  • 7 posts
  • Local Club: minis and oatcakes
Posted 15 May 2007 - 04:48 PM
hi just got a mini ,for my boy but today the wipers packed up ??????????
any one give me a little info on what to check
#2 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 15 May 2007 - 04:54 PM
have they packed up completely?
The other day, mine went funny - they won't work on the first flick of the stalk but will work when I flick it again to the top, and when i pull the stalk back down they stop in the place they are and don't return to the bottom... I think this is either the Wiper Motor Park Switch or the terminal which connects to it.
On my car (might be different on yours) as you look in the bonnet it's to the top right hand corner and the park switch is a small grey square thing. Try switching the wipers as if they were on and fiddling with it and see if they work. If they do you'll know it's that that needs replacing.
Of course I might be way off and it could be the actual wiper motor which I imagine is sited very near to the park switch - someone else might be able to add to this to help... :(
#3 od161
od161
    Just On Tickover
  • 7 posts
Posted 15 May 2007 - 05:32 PM
yes they gone all together, i will try what you said thanks
#4 od161
od161
    Just On Tickover
  • 7 posts
Posted 15 May 2007 - 06:17 PM
thanks
just taken the top off the motor, the motor has parted company with the cable end is all chewed ,cant see how it attachs .do i need a cable replacement or can it be repaired
#5 triger
triger
    Starting My Mini Up
  • 3 posts
Posted 17 May 2007 - 09:54 PM
Of course I might be way off and it could be the actual wiper motor which I imagine is sited very near to the park switch - someone else might be able to add to this to help... ^_^
thanks
#6 triger
triger
    Starting My Mini Up
  • 3 posts
Posted 17 May 2007 - 09:57 PM
thanks
your best bet is to try local scrapie for new motor and mecanism wont b more than a tener
