998 gearbox onto a 1275
8 replies to this topic
#1 a2lt16v
a2lt16v
  • 255 posts
Posted 23 November 2004 - 08:48 AM
if yes any one know whats the best type of 998 garbox to use
they had different final drive values didnt they?
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 November 2004 - 09:15 AM
basically there's no difference between a 998 and 1275 gbox... the differences are to do with the age of the vehicle.
If we just deal with Rod Change boxes, there are two basic sorts PreA+ and A+
A+ gearboxes are normally identified by a large diameter bearing for the idler and a grove down the middle of the gears, they also have a slightly different pitch angle of the gear, which is all to make the box quieter.
Pretty much all A+ boxes have the same ratios, with the only difference being the final drives (diff), which is age and source dependant..
A series boxes have a smaller idler bearing and no grove... and also have slightly different ratios to the a+
You also can get Close ratio boxes ( fitted to old cooper's and gt's )
Also look at thread....
http://www.theminifo...?showtopic=3851
You need a gearbox which has the same size idler bearing as the one pressed into your crankcase cover...
Large idler shaft diameter = .875"
Small idler shaft diameter = .750"
#3 Alex1380
Alex1380
  • 309 posts
Posted 23 November 2004 - 09:18 AM
no they won't i can't remmber why but we were trying to put a 1100 gearbox on to a metro 1275 and it wouldn't gear together
ill find out why tonight and post again.
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 November 2004 - 09:22 AM
They wont gear, generall means you were attempting to combine different pitch gears, I suspect the 1275 was a metro with an A+ Primary, and idler, and the gearbox was an Pre A+.
You cannot mix and match between A series and A+, unless you have the complete drop gears from one and the gearbox from another.
#5 a2lt16v
a2lt16v
  • 255 posts
Posted 23 November 2004 - 09:34 AM
dunno what it is its off a 998 1992 model and the little 998 block is warped so head gasket keeps going so i was gonna put a recon 1275 in it
but the gearbox on the 998 is good
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 November 2004 - 09:40 AM
With that age, if you drop a 1275 from a metro, there will be no fitting problems at all...
If you do got that route, you'll obviously want a 1275 head aswell, so you'll also need a top radiator hose and bracket for a 1275 ( the angle is different to a 998 )
#7 a2lt16v
a2lt16v
  • 255 posts
Posted 23 November 2004 - 09:43 AM
cheapest i have found one reconditions is 450 with recon head to
all but no gearbox
what about the clutch
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 November 2004 - 09:51 AM
take the complete flywheel/clutch from your 998 and stick on to the 1275, job done....
As for a recon engine for 450 ??? hmmm... You can get a morspeed 1293 kit for 350 notes... gives you 100 notes to find a head on ebay !!!
http://www.morspeed....engine_kits.htm
#9 a2lt16v
a2lt16v
  • 255 posts
Posted 23 November 2004 - 10:00 AM
is that enough money for one are they special heads
im only just into minis and got 1800 to do mine up and get girlfriend new engine
mine is have new floors sills and steps at moment then new rear panel then being sprayed and girlfriend (mini_claire) needs an engine
