engine and subby
Posted 18 May 2007 - 06:34 PM
ok how do i undo the steering from inside the car??
and do i undo the subby from inside???
Posted 18 May 2007 - 06:40 PM
Posted 18 May 2007 - 06:44 PM
then the tower mounts ??
thanks for a fast reply
Posted 18 May 2007 - 06:52 PM
Posted 18 May 2007 - 06:56 PM
cheers again
Posted 18 May 2007 - 07:09 PM
Posted 18 May 2007 - 07:32 PM
just one thing if i get under the car and undo the bolts will it fall on me lol
or is it ok aslong as the 2 main tower bolts still on
basicly i have everything undone and the car is on the floor wots the best way to do it??
sorry for being a noob just want to make sure im safe
Edited by ministudio2, 18 May 2007 - 07:32 PM.
Posted 18 May 2007 - 07:44 PM
Posted 18 May 2007 - 07:45 PM
Edited by ministudio2, 18 May 2007 - 07:48 PM.
Posted 18 May 2007 - 07:46 PM
The way I've done it is just to remove everything except the tower bolts, make sure the frame is supported and then lift the shell over it. Two people can do it easily. It rolls like a wheel barrow with the handbrake off. You need an amount of timber standing by to support the shell while off the frame. Don't venture inside a car with the subby loose either.
Oh yeah, and take the carb and dizzy off and radiator out if you haven't already. It gives more clearance.
Edited by Dan, 18 May 2007 - 07:48 PM.
Posted 18 May 2007 - 07:53 PM
i already cut the front off
