Hey Everyone
I am going to have to put some new valve guides in my ported 12G940 Head my dad says that years ago that he used to put the head in the oven and the valve guides in the freezer and then pull them in the head with a long bolt and a metal plate will this work
Many Thanks Chewy
Valve Guide Fitting
Chewy
, May 20 2007 05:43 PM
5 replies to this topic
Posted 20 May 2007 - 05:43 PM
Posted 20 May 2007 - 05:49 PM
That's the basic principle of interference fit mechanics, yes. If you're confident, give it a go. I would be inclined to hand it to a machine shop though. You tend to find that replacing the guides often positions the valve ever so a slightly different, requiring the seats recutting.
Posted 20 May 2007 - 05:56 PM
Many Thanks
Why do the seats need recutting for
Edited by Chewy, 20 May 2007 - 05:56 PM.
Posted 20 May 2007 - 06:20 PM
the guides will also need reeming out after being pressed in
Posted 20 May 2007 - 08:42 PM
The seats will require re-cutting because there is no garantee that the bore of the new guide will be in the same place as the guide you have replaced, so the seat could be off set slightly, also depending on how worn your old guides were you could now have an oval valve seat!, at work we charge £4 to fit a guide and £4-£6 per seat to re cut, this includes honig out of the guide to size.
Posted 25 May 2007 - 07:38 PM
The old guides are not that worn when i took out the valves i am goin to ream the valves on my dril press with a new tool i got yesterday
Chewy
Chewy
