having tried 2 sorts of grease on the clutch plunger and long clutch arm I find that I am needing something which does not dry out and start to sieze things up when it dries out and goes rock hard. I have used multi purpose lithium based grease (the yellow stuff) and now that black grease (molybendium?) for cv joints; on inspection today the grease has dried out and consequently snapped the ball off of the end of the clutch lever. Out comes the landy till i get a new arm in the post next week
What about copper grease? will that dry out with the heat from the engine?
what do you chaps use??
oh and also, its a diaphram clutch with the long arm.
