Replacing my A series 998 with an A+ 1275 from a Metro. The clutch in the Metro is cable.
From what I read on Minispares.. The transfer is swappable between the two, meaning I can use my non verto type clutch slave cylinder on the A+ verto 1275.
Is this correct? And is it just a simple swap over job or is there something more indepth I need to look at.
Or am I better off buying the Verto type slave cylinder and bracket?
Cheers for anyone who can clear this up for me.
A series and A+
jack_marshall
, May 28 2007 12:10 AM
3 replies to this topic
Posted 28 May 2007 - 12:10 AM
Posted 28 May 2007 - 07:20 AM
if your current vehicle is a pre-verto (look in the FAQ's for guidance) then you will need to the verto slave hydraulic setup.
The complications come if you are swapping from a inertia starter to a pre-engaged, at which point it may be easier ( if you dont want to be changing electrics ) swapping the flywheels over.
Posted 28 May 2007 - 12:16 PM
Just use the flywheel/covers and starter from the 998 - it's a far better set-up and won't cost you a penny!
Posted 28 May 2007 - 05:29 PM
Yeah thats what we've done.
Dad did some jiggery pokery with covers and arms and it should all work now. Going to wack a new clutch plate in tomorrow too just for good measure.
