camshaft change question
9 replies to this topic
#1 bennivory
bennivory
  • 72 posts
Posted 28 May 2007 - 06:11 PM
hi, im goin to be changing the camshaft in my 1275gt to a kent 276. my oil pump is a spider drive and i was wondering which type of oil pump drive the 276 is. if it is not spider drive, is it possible to just change the oil pump to the appropriate drive?
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 28 May 2007 - 06:27 PM
kent are normally slot driven oil pumps
#3 bennivory
bennivory
  • 72 posts
Posted 28 May 2007 - 06:35 PM
so would it be possible for me to just change my oil pump to slot drive?
#4 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 28 May 2007 - 06:39 PM
Just buy a slot driven pump or whichever you require (to match your cam)
It is generally seen as "normal" to replace the oil pump while the engine is apart anyhow.
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 28 May 2007 - 06:40 PM
Yes. Buy a slot drive pump to match your cam if that's what drive type it has.
#6 bennivory
bennivory
  • 72 posts
Posted 28 May 2007 - 06:58 PM
thanks a lot guys, thats what i needed to know. cheers
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 28 May 2007 - 10:52 PM
...you do know your going to have to strip the driver side of the engine down to do it right?
#8 bennivory
bennivory
  • 72 posts
Posted 28 May 2007 - 11:09 PM
im in the middle of an engine rebuild mate, thats why i want to get it done now while its out
#9 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 28 May 2007 - 11:15 PM
its a bit more than that dude, its a full engine strip down to change the cam...unless you want the followers rattling around your gearbox.
its also common practise to fit new followers at the same time as a new cam dude so definately not an in car job on a 1275.
#10 bennivory
bennivory
  • 72 posts
Posted 29 May 2007 - 11:15 AM
its pretty much stripped already as im paining the block.
