fitting an mg metro engine
11 replies to this topic
#1 wingman
wingman
    Just On Tickover
  • 9 posts
  • Local Club: n/a
Posted 02 June 2007 - 09:35 PM
hi i have an mg metro engine to fit in my standard mini 998 there seems to be many different components ie the water hoses to the manifold etc what do i need to actually replace on this engine to fit it to my car . i read about the starter .can i still use the verto clutch ?how do i get that to work .what about the themostat do i just swap housings?any help will be useful thanks
#2 Joef
Joef
  • 518 posts
Posted 22 June 2007 - 05:47 PM
Same question, i can get hold of a g reg mg metro and would like to use the engine. How much work is it to swap them and is it worth doing? Im on a standard 998 atm and id like a bigger engine before i go to stage one.
Thanks in advance.
#3 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 22 June 2007 - 06:01 PM
You need different engine mounts for a start, but everything should fit and work.
I imagine you can drill and tap the head for the Mini heater take off, or just connect up the hoses as per later Mini models.
#4 charminbear
charminbear
  • 352 posts
  • Local Club: P&S
Posted 22 June 2007 - 06:10 PM
You shouldnt need different engine mounts, you just have to remove the mounts from the rad side on both engines and pop the Mini one on the metro engine - just watch the top screw on the mini mount as it can be a PITA.
You will also need to swap the bell housings for the clutch over as the Mini one has an engine mount on it - metro one does not. You should be able to swap the clutch from the mini onto the metro engine too.
You might need to swap the thermostat housings over - that is easy enough, I seem to remember you might need a different top rad mount (I already had a front mounted rad so dont quote me on that - I could be wrong)
If you want the heater to work you will need to drill a hole in the head for the heater tap.
We managed to remove both engines in a day (metro engine was in the metro still) and get it in the mini on the 2nd day..
#5 Ethel
  • 26,088 posts
Posted 22 June 2007 - 06:18 PM
Direct swap, use as much of the metro as you can - where you can't use the minibits.
Only issues...
Heater take off - drill and tap to suit (1/4 unf)
Engine stabiliser bolt holes in block - may need a tap running through them
Bypass hose - use mini thermostat housing and drill a few 1/4 inch holes in the thermostat.
Clutch - All verto or all non-verto and starter motor to match (I'd go none verto)
Chances are your speedo will be out - if you're on 12 inch wheels you may be able to put it right by swapping speedo drive on gearbox.
#6 Ethel
  • 26,088 posts
Posted 22 June 2007 - 06:29 PM
1275 rad mount was different because engine is a bit taller than 998 - as long as the fan isn't going to go through your radiator...
#7 Ethel
  • 26,088 posts
Posted 22 June 2007 - 06:31 PM
obviously use metro manifold, carb, ignition.
#8 JoeBodge
JoeBodge
  • 716 posts
Posted 22 June 2007 - 11:04 PM
the manifolds should be the same as a mini's
#9 Ethel
  • 26,088 posts
Posted 22 June 2007 - 11:17 PM
they'll fit won't flow as well which'll effect carb 'n ignition setup
MG metro inlet and an after market lcb is about ideal
#10 Bosh
Bosh
  • 38 posts
Posted 21 May 2012 - 10:18 PM
wow found this usefull guys as putting a 1275 a+ in my mini :D
Bosh
#11 stickycreambun
stickycreambun
  • 1,865 posts
Posted 21 May 2012 - 10:39 PM
Hope it didnt take nearly five years!
:teehee:
#12 bmcecosse
bmcecosse
  • 9,699 posts
Posted 21 May 2012 - 10:40 PM
Just swop over bits from the old engine as you go......
