Seen these 2 products in asda. has anyone ever used wynns super charge oil treatment or nitrox hot shot? And could smartprice 20w50 be used to flush the old oil out when changing oil...? (i have some mayo left in the current oil)
Wynns oil treatment/nitrox
Protarmic
, Jun 10 2007 04:35 PM
4 replies to this topic
Posted 10 June 2007 - 04:35 PM
Posted 10 June 2007 - 05:59 PM
Tesco and asda oil is good for flushing the oil out etc, because its a good thickness and its cheap.
Never heard of the other stuff, i dont believe in the oil treatments. I would just change the oil regularly.
Posted 10 June 2007 - 06:04 PM
A good quality oil will already have all the additives it needs !!! Adding a large extra quantity of one will upset the balance and is a recipe for problems !
Posted 10 June 2007 - 06:08 PM
Ahh. Just wondering, the oil treatment mentioned its good for town driving. And i do that alot now.. i think thts wy i have mayo even after a head gasket change
Posted 11 June 2007 - 12:34 AM
Regarding the nitrox Hotshot, Yeah I've used this - and I actually had a boost of power while it was in the tank (one bottle to a full tank - bottle only treats 15 litres), Though my car was not "tuned" to use the increase in octane rating, my car was (still is) in need of the timing adjusted and / or mixture (still a little "lumpy" and gutless on hills), so may have been closer to what was needed for the nitrox to do something. Prob timing too advanced and running rich.
Word of warning though - the main "active" ingredient of this stuff is METHANOL (65% methanol, + "other"(?) additives - this is not listed on the bottle, only in certain chemical safety / handling data sheets), and methanol is NOT good for plastic fuel lines (unless Methanol / Ethanol compatable or copper line is used), rubber (seals, fuel line etc.) unless alcohol tollerant, and most of all ALUMINIUM (and guess what the carb / inlet is made from!).
In short - Yeah it works, but just don't use it every day or you'll find it's eating your fuel system! will be fine for the "occasional" use, but obviously you would need to adjust you engine to make full use of it, each time.
All in all, not worth it, unless your doing a track day event or something similar. Might be good to clean out some of the "gunk" that builds up, once a year though.
SS
SS
