megasquirt ECU
Posted 02 December 2004 - 06:32 PM
I have been on the megasquirt site and it looks like the cheap answer to an expensive problem :grin:
I was thinking of useing a pair of motorbike throtle bodies
unfortunatly i have never done any electronics building before :sad: and find the idea of building my own ECU from a box of bits a bit daunting
Anyone tried this ?
Posted 02 December 2004 - 07:27 PM
Or are you going for a mad racer engine that the ECU and injectors won't cope with?
Posted 02 December 2004 - 07:37 PM
Megasquirt is my latest project, hence the Monte I now have.
I have my kit on order and once I am happy it works in mini PROPERLY I plan to sell kits, built ecus and offer mapping.
What spec of engine are you going for... MPi is going to be much harder to get to work... if SPi will meet your requirements it would be much cheaper and easier to go that route!
Alex
Posted 03 December 2004 - 08:10 PM
I'm only using it for the mapped ignition though, siamese ports and all that.
Wil
Posted 03 December 2004 - 10:19 PM
I am still in the planing stage and trying to find out what will work best , I am considering converting a 40DCOE webber into throtle bodies , or maybe using two motorcycle bodies , this was the route sergested when i disscust it with a firm that fitted weber alfatronic (was too expensive)
single point may be easier to build and set up , one of the mags have said it is possable to convert a SU to a throtle body (this would be good for under bonnet origionality).
as megasquirt has no ignition built in I am planing to use edis(think that is what its called )
any and all info on this project would be greatfully recieved .
Posted 03 December 2004 - 11:35 PM
Posted 04 December 2004 - 08:48 AM
Personally it looks very expensive, How much is the kit and does this include all the sensors, air flow, TPS ect? How much time would you expect to spend building it and getting it running correctly. Time being the most expensive part of the build.
I would not have the electronic knowedge to be confident enough to build one or more importantly the time,
Siggy
PS good luck to thoses who go that route
Posted 04 December 2004 - 06:18 PM
The advantage over carbs is the MUCH better control of the air fuel ratio, which if you combine with proper spark control means in theory you could run a 286 cam in a road engine and it would drive fine on the road!!It looks very iinteresting. But what advantage would you have over carbs?
Siggy
It is expensive but there are ways to keep the costs down.
Time is the huge issue, there has been very very little development for minis on the injection front other than the "replace all that electronic stuff with a carb" nonsence!
To build a megasquirt ECU is suppose to take about 4-5 hours the 1st time you do it. Then there is the all the time to install it and get it working!
The reason I brough my Cooper Monte is to develop a plug in kit that works in minis as an easy solution for anyone who either has injection, or who wants to play with it.
Alex
Posted 04 December 2004 - 06:33 PM
Do you plan on using one injector into the inlet? Which would you use?
Are you going to buy all the bits that are needed from DigiKey/megasquirt so that you just put it all together without going around everywhere trying to find tiny components?
Where are you getting all the sensors and which ones are you going to be using etc.?
Just a basic idea of how you plan on getting this to work on a mini engine since I am now rather interested in this whole thing, and I'm sure many people would be!
Posted 04 December 2004 - 06:46 PM
The plan so far is:
Using a std SPi manifold and all associated sensors the std Rover MEMS system used. The reasoning behind this is to create a replacement mappable ECU for modified injection minis that simply plugs into the std loom.
Next I will repeat the above but with a MPi engine (oh good another mini I need to buy!!).
After these two cars I will have good base maps to be able to offer other injection solutions, such as converted SUs/webers or Jenvey Throttle Bodies.
I also hope to offer kits so people over here don't have to worry about DigiKey... but in the mean time the best place to get them seems to be:
http://www.glensgarage.com/
Alex
Posted 06 December 2004 - 07:55 PM
Posted 08 December 2004 - 08:19 AM
IIRC the heads on injection cars are differnt to carb ones?
When fords changed the escorts from the K jetronic to efi they had terrible running problems, they tried changind it but never managed to cure them. I was told by Ford technical, that this was because they never developed the cylinder head to suit the change.
Siggy
Posted 08 December 2004 - 09:36 PM
The heads are the same no redesign needed.
SPi is still better than a carb as you have better fueling control at all throttle positions and engine loads, not a guess like carbs are!
"When fords changed the escorts from the K jetronic to efi they had terrible running problems, they tried changind it but never managed to cure them. I was told by Ford technical, that this was because they never developed the cylinder head to suit the change."
Which engine are you talking about?
Alex
Posted 08 December 2004 - 10:08 PM
you need a large venturi (i think thats the right word for it )for big HP but a large carb works C**p at low engine speed because of low vacuum does not atomise the fuel very well , this is made even worse if you have a cam with large overlap,, now with injection fuel delivery is not dependant on air speed at all so you can have your large throtle bodies (for big air flow) and a perfect mixture even from very low revs with a cold engine under heavy load
try puting your foot to the boards at low revs with a 40 dcoe and a big cam and all you will do is get it to spit back and set fire to your air filter !
and not only that , but the increase in mpg means it should pay for itself
Posted 09 December 2004 - 01:16 AM
AFAIK the only changes to the heads for injection involved different bracketry for accessories and ports for sensors. The combustion chamber and porting is pretty much unchanged.
You still don't want a really massive throttle body, just one that's big enough.
