help! can i use the standard timing dots on duplex timing gear to time a kent 266 cam advantages? disadvantages? im new to it so i im dont know what a woodruff key is and what not please help
Timing for kent 266 on duplex timing gear??
Surfbluegarage
, Jun 13 2007 06:46 PM
6 replies to this topic
Posted 13 June 2007 - 06:46 PM
Posted 13 June 2007 - 08:56 PM
best results = time it in properly (plenty of instructions about in the tuning books, web sites, etc)
it would work dot to dot, but if you want the best out of the cam you have bought... then time it in properly...
ttfn,
Dave
ttfn,
Dave
Posted 13 June 2007 - 09:39 PM
Something I never got.
If the cam need to be out by "X" amount. Why not grind to that so the dot to dot still works out fine?
Posted 14 June 2007 - 08:19 PM
Two simple reasons:If the cam need to be out by "X" amount. Why not grind to that so the dot to dot still works out fine?
(1) - Manufaturing tolerances - production runs can and do run wide tolerances so are often not exact. this is true for both the cam, crank and timing gears.
(2) - Altering the cam timing eitherway can alter the charecteristics of the engine - ie more peak power, or more low rev torque.
ttfn,
Dave
Posted 15 June 2007 - 07:23 PM
does anyone know how i would go about timing my cam for the best performance out of the cam?
Posted 19 June 2007 - 07:44 PM
yep,
but you can read it in a book - vizard one will show you how... or google it... or search mini sites..
(in fact there is a guide on Turbominis...)
Posted 19 June 2007 - 07:54 PM
I might add as no 2 engines, especially modded ones, are the same the only way to get the absolute most is with a rolling road.
That'd be expensive so I'd get all the advice / info you can to make an educated guess at what will suit your particular setup.
