dog gearbox
26 replies to this topic
#1 moonmini
moonmini
  • 46 posts
Posted 14 June 2007 - 04:54 PM
Hi, could someone tell me what the difference between the dog gearbox and the normal straight cut rod change 4synchro gearbox? and would the dog box be ok on my 1380 road car, or is it just for race use only? thanks, richard
#2 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 14 June 2007 - 05:00 PM
basicly a dog box doesnt use syncromesh engagment, ether double clutching is required or working out each rev to gently slip into place (doesnt always work how it sounds)
dog box's are used on high power engine's usualy, so should go on the 1380 fine but as would a normal syncro- straight cut box
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 14 June 2007 - 05:58 PM
Oooow. Thats what a dog box is.
Learn something new everyday.
#4 supermotolee
supermotolee
  • 1,120 posts
Posted 14 June 2007 - 06:11 PM
i thought dog box meant first was down and to the left?
#5 alexcrosse
alexcrosse
  • 3,786 posts
Posted 14 June 2007 - 06:12 PM
for road use id go for a syncro with straight cut drops, (huh guess works! lol) All you need for a 1380. Drops to stop side thrust from helical gears cracking the gearbox casing and to make a nice whine :wacko: If its for road use you might find it a bit tedious double d clutching all the time, crunching down the road =p But its another toy isnt it =p something nice and novel for a road car. Your choice. Have fun with it!
#6 mini93
mini93
  • 8,615 posts
Posted 14 June 2007 - 07:16 PM
i think thats just down to how the selector forks are aranged in the box
sequential box's work about a twisting rod which locks into different points engaging gears, obviously lock into a certain order "sequentialy"
#7 supermotolee
supermotolee
  • 1,120 posts
Posted 14 June 2007 - 11:23 PM
yeah a selector drum (like a motorbike) just alwasy thought a dog box was something to do with dog leg first gear or something just me randomly thinking outload dont worry
#8 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 15 June 2007 - 01:31 AM
thats dog leg. :wacko: like in the ferrari's (older ones anywhow)
Edited by mighty_mini, 15 June 2007 - 01:32 AM.
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 June 2007 - 07:46 AM
Also with bog boxes, the gears are substantially wider and stronger. This is because the space previously used by the synchros is now available... There are a number of dogbox gearkits on the market, generally either 12 tooth dog kits (eg JKD involute set) or 7/6 tooth dog kits (eg Quaife / MED )
Personally I would not bother with a 21 tooth kit as it's almost the same as trying to use a std box with no synchros, where as the 7/6 tooth kits are real clutchless gearchanges...
As for road use.. your choice.
#10 danwebster
danwebster
  • 637 posts
Posted 15 June 2007 - 08:08 AM
Have you used a Jack Knight involute dog kit GW? I always found mine a joy to use, the only reason i've changed to a swifty box now was to change my gear ratios, otherwise i'd still be running the JKD box.
:wacko:
#11 Bam
Bam
  • 1,331 posts
Posted 15 June 2007 - 09:00 AM
I wouldent use a dog box for a road car.
Its not nessary as a straight cut gearbox would be perfectly adequate and you wouldnt need a dog box for every day use.
I also think that you would start to find it annoying as you cant drive it like a normal car.
Get the straight cut box, for road use its perfect.
Chris.
#12 danwebster
danwebster
  • 637 posts
Posted 15 June 2007 - 11:58 AM
I don't mean to cause an argument here, but do you have experience using a dog box on the road?
I've done 3000 road miles with one and found it no more difficult than driving a synchro box, whilst I agree its complete overkill on most engines, I get annoyed at people spreading mis-information through lack of understanding.
Rant over.
#13 mini93
mini93
  • 8,615 posts
Posted 15 June 2007 - 12:03 PM
hes used dog box on a fully kitted 205 rally car driving back from wales i think it was
#14 Bam
Bam
  • 1,331 posts
Posted 15 June 2007 - 12:16 PM
Rant over.
I have had experiance, and I know what you mean, once your used to it then its just like a normal car. But I could just imagine it just becoming annoying ocaistionally like in town.
also there is a huge cost diffrance.
Chris.
#15 danwebster
danwebster
  • 637 posts
Posted 15 June 2007 - 01:27 PM
Absolutely, I ran a sunchro box in mine for over a year as I couldn't afford a dog box, I was forever breaking baulk rings and even teeth off the gears so I had to bite the bullet in the end. It was the best move I ever made with my car.
You're right though, they are prohibitively expensive for most.
