Spax Coilovers
Posted 18 June 2007 - 09:09 AM
Do we need to mod the bodywork or do I need different trailing arms?
Posted 18 June 2007 - 09:20 AM
Posted 18 June 2007 - 09:34 AM
There is a coil over shocker with offset mountings if you're not already using it.
If someone was to measure up their standard mini ( Between the inner ends of the swivel pins perhaps? ) that'd tell you if it was down to the beam axle. I've got a similar set up so I'd be interested to know too. I made my own beam, 48 inches between the outer faces of the swivels. That too seemed a little narrow, but it's not on a Mini shell.
i think it'd be easiest to "cut 'n shut" your beam to add some width
Posted 18 June 2007 - 09:41 AM
As above, the Spax coilovers are usually offset, so make sure your guy has them on the correct side, otherwise it will be offsetting the unit further into the inner arch. When I fitted the rears the inner arch just need a bit of gentle persuasion right at the top of the turret.
Posted 18 June 2007 - 09:48 AM
I've just downloaded the Spax fitting guide from here:
http://www.spax.co.u...ssic/index.html
It mentions modding the top of the arches with a hammer, but nothing about the clearance on the lower par tof the springs.
Sounds like the beam may be too narrow and causing the bottom of the coilovers to be pushed toward the arch.
What bad things have been said about this beam? Is this a known problem? Would I be better off going for this?
http://www.minispare....aspx?pid=38131
ETA: Just spoke to Mini Spares and there are no mods needed with the kit I have as they are offset to avoid the need for this. Sounds like the mounting points or geometry of the trailing arms is wrong somewhere.
Edited by NikB, 18 June 2007 - 09:53 AM.
Posted 18 June 2007 - 10:00 AM
When i fitted wheels back on, they were very badly toeing in and the outer radius arm brackets needed shimming to correct it which unfortunatle means that the spring will be even further inboard... as long as the area isn't rusty, i'd be going the hammer route .
Edit: i wrote lover flange instead of lower!!!!!
Edited by biggav, 18 June 2007 - 10:00 AM.
Posted 18 June 2007 - 10:03 AM
Thanks for the advice guys.
FraMini one is available again via TDK racing and is less than £100 i think. The one in the link is the same as the P+L one but cheapest from Mini Spares by atleast £15 when you add the postage and packaging costs.... (also you get 5% discount when you mention your TMF username.)
Posted 18 June 2007 - 10:52 AM
David
Ps
I have the minispares alloy beam for sale if you still want to go down this route
Edited by R1mini, 18 June 2007 - 10:53 AM.
Posted 18 June 2007 - 01:47 PM
Posted 18 June 2007 - 01:56 PM
Posted 18 June 2007 - 08:22 PM
is there any problems fitting coilovers to the std read subframe?
no, it will all fit but all the subframe does is hold the radius arms and susension bits... once you take the suspension bits away, its just dead weight.
Posted 20 August 2007 - 08:43 AM
The other issue we now have (it never ends!) is that because it's stripped out the back is now sitting too high, even with the coilovers wound to their minimum height. Spoke to Spax and they are saying they are progressive springs so cannot tell the the poundage to buy a lighter set of springs. Anyone know what others run? People must have changed these before....
Oh and heres a pic...
Posted 20 August 2007 - 08:47 AM
Edited by Matt, 20 August 2007 - 08:49 AM.
Posted 20 August 2007 - 10:01 AM
Weigh the back end of your car, even bathroom scales under the wheels will be accurate enough. average the weight for each wheel (L+R / 2). you'll need to know the free length of the springs and how far they need to be compressed to give the desired ride height (with the spring seat mid damper to allow some adjustment) to work out the right poundage you require
Eg. 15 inch spring, 10 inch ride height is 5 inches per side. Say each rear corner weighs 250lbs: 250/5 = 50lb springs.
Still odd as my plastic kitcar can't weigh any more than yours and sits happily on standard Spax coilovers.
If the beam's just 1cm too narrow can't you make spacers, and outer brackets if req'd, as that's only 5mm per side?
Posted 20 August 2007 - 06:11 PM
